Toslink Output from DSpeaker Antimode 2.0 into NAD M51 - Help
jmasi07
Folks,
Currently using a NAD M50 player to stream into the room correction Antimode 2.0 and the output digital is only toslink which is input into the NAD M51.
Am I loosing any fidelity in the music and can I up-sample toslink (D to D) to use the USB/HDMI/AES inputs of the Dac. Any suggestions welcome. Thanks
John
tw99
West Berkshire, UK
I believe that the Antimode 2.0 always outputs digital at 48Khz/24 bit, no matter what input it's fed. So if you're the sort of person who thinks that's a problem, then it's a problem. In reality, you won't be losing any fidelity.
Personally I use the Antimode 2.0 as the DAC in my system, it works fine.
