Hi
All anecdotes..probably repetitions.
Long time no post, I am well , have been very (good) busy.
As an EE, understand the notion of SINAD, put it aside .. I am in IT so ,, yeah, it surfaces once in a while.
then came ASR and SINAD became an important metric , one by which upstarts, cheap and lean were slaughtering the HEA darlings (Topping!! SMSL!!!) and it came to be the King metrics in our minds.. If SINAD is high, then Audio performance was high (true) .. but.. How high ? and can we hear the differences everything else being the same? .. At what level does it really matter?
Then we learned that the cherished vinyl, and the even more celebrated R2R .. can barely do 70 dB, and in the case of Vinyl chains, 50 dB, is where their measured SINAD lands .. many are 45 dB or less ... regardless of price .... (Just saying , meanwhile the $25 CD transport available at Walmart could well be doing 80 dB all day long with flat 0 dB variation 20 to 20 KHz .. in passing , yes, in passing)
Seems based on various studies, that we cannot distinguish reliably 80 dB from 90 or 100 or 120 .. 80DB seems to be the brickwall for most people.. Someone coudl prove me wrong but 100dB is not the brickwall threshold ...
And most AVR do 85 Db routinely..
We also know that calculating the SINAD of a chain of component is complicated, complex (it involves complex numbers
and Euler number and ...) but let it be known the SINAD is low-bound by the lowest SINAD in the chain ... so 100 dB SINAD amp, with a 25 dB SINAD preamp gives you <25 DB SINAD chain ...
OK
But remember our sisters and brothers from the other side? Those with Vinyl and expensive TT and Tubes preamp and RIAA correction and .. expensive cables.? . They are well under 50 dB, yet purport that it sounds sooo good, that even their spouse in another zip code could hear the difference ...
The elephant in the ROOM.. is the
ROOM itself .. it mangles whatever comes from the loudspeakers and soils it, brings it down, especially in the bass where 30 dB swings are commonplace ... Then, one realizes that what makes things sound good is not SINAD , that most decent components clear the 70 dB threshold (most AVRs) , and that what you hear, is
through the room , from the room and the loudspeakers interactions . DRC can mitigate the room's impact, its reach and MANY AVRs come with it built-in ... no extra price and with more than 2 amplifers
So many AVR come with ROom Correction and to me it is one of the greatest gift from these AVR...unsung heroes of excellence in Audio Reproduction.
An AVR costing $1200 is a superior DRC -machine, if you know how to use that capability and while most people will struggle, to hear the differences between 75 dB and 80 DB of SINAD.. with or without is really DRC, invariably NIGHT and day... even your spouse from the kitchen .... will hear it ..
And if well implemented .. DRC is transformative. I currently am using OCA scripts and these are game-changers.. with Denon or Marantz AVR , things are transformed from good to superlative.
WHich brings me to my current state of things : For, almost 10 years I've had the same system (!!
..) A cheap Denon AVR-X3400 { purchased refurbished at Accessories4ess.com + a pair of JBL LSR-308 (circa $400 pair) + a pair of Dayton SUB1500 about $250 each + OCA scripts and it has been the best system I have had in my 50 + years of being an audiophile .. it is full range 20 to 20,000, can reach 110 dBat the listening position (both measured ) and is a constant(daily) source of joy and yes, of elation ...All that for less than $2500...
AVR should be the center of ANY audio system .. PERIOD..
