Topping Quality Issues?
ilovegold
The replacement just arrived and seems to work perfectly. Yay amazon for speedy service for once.
M
monkeyboy
Following up on my own post..I purchased a D50 in May 2019
My D50 has developed a channel imbalance (left channel louder than right) when using USB.
The problem does not exist using TOSLINK from the same motherboard. I tried my old JDS O2 DAC via USB with no issue.
So the problem appears to be with the D50
I'm talking to Topping about the issue...
gvl
SoCal
Odd this is USB only. Are you sure the balance in the Topping sound device settings isn't off?
M
monkeyboy
Yes, USB only.
There is no balance adjustment on the D50. The issue seems to be in the difference in signal paths, USB vs TOSLINK internal to the device.
gvl
SoCal
Yes, USB only.
I thought balance adjustment is available on all devices in the OS. However if you use exclusive mode or ASIO on Windows it may not have any effect - not sure.
M
monkeyboy
I'm running Linux and made no changes to my config when changing USB DACs, so I don't believe it is the audio chain on the PC
Snafu
yes, go to option menu : 5 factory reset
RT*M :D
M
monkeyboy
I need to retract my post above regarding a balance issue with the D50...Embarrassingly, the problem was entirely on my end.
There is no issue with the D50
L5730
East of England
So what did you do wrong that caused you to think there was an issue. No embarrassment need be felt, we're all human, we make mistakes. Admitting error and learning from it, and even helping to prevent others making those same errors, that's nothing to be embarrassed about. :)
M
monkeyboy
I switch to Mint recently from OpenSUSE. When I had the balance issue I popped open the Sound Control Panel and got what is shown below...no balance slider?? I figured it was somewhere else, so I looked a amixer, alsamixer, pusle_effects...nothing?...I had no reason to play with it and figured if I couldn't find it, it must be OK...The issue I was having only happened with the D50 in USB mode, TOSLINK worked fine, analog worked fine, a separate USB DAC worked fine?...I was stumped...
Digging around on the net I noticed a Mint screen shot showing the balance slider in the Sound Control Panel...huh?...It ends up that when the Panel is re-sized, it doesn't scale the contents, it crops....so the controls were there just out of view....dumb-ass....I still can't explain how the balance got changed....
I'd like to mention I had a email chain with Topping during this and they were awesome...great company!
