这种多路输出直接分线器就行了为啥要前级?需要单独去做的是多个输出去选择。实际上HIEND用户需要多路XLR输出以实现BI-AMP玩法。而3甚至4输入 完全没必要
XLR/RCA输出1分2转换头是否会影响输出阻抗? 并且据我所知 并没有高质量的XLR1分2转换头吧这种多路输出直接分线器就行了为啥要前级?需要单独去做的是多个输出去选择。
不会有影响。XLR/RCA输出1分2转换头是否会影响输出阻抗? 并且据我所知 并没有高质量的XLR1分2转换头吧
It's not even announced yet. So no ETA.It was already asked at least 2 times in this thread without any answer..another trial... when the preamp 90 will be available?
ok but any targeted date? Like end of 2020...It's not even announced yet. So no ETA.
Isn't HT bypass just setting the preamp to 0dB? Or is there more to it?I had a discussion with Topping about HT bypass about a month ago, and while it is too late to include it in the first version of the preamp (as pre-development is complete), they will look at including HT bypass in the 2nd version of the preamp. Topping sees the value of this important feature.
Yes, it is. But some people are lazy or just afraid to leave the volume maximized for HT, then switch the input and forgot that music was playing and volume 100%, music blasts through the speakers! It's an easy "convenience" solution to enable HT bypass (max volume) for an input and the other inputs have it disabled using the volume set to a normal listening volume.Isn't HT bypass just setting the preamp to 0dB? Or is there more to it?
Pre90 has an optional extender.
Pre90 itself has the same IO as A90 on the back. 1 XLR + 1 RCA for both inputs and outputs.
Extender has extra 4 pairs of XLR inputs and 1 rca input. No extra outputs.
It has cut down A90 NFCA circuitry but still much more powerful than majority of headphone amps. But it's a preamp.
Relay switching volume control for best distortion and great separation.
Has a screen. Has a remote. Has safe volume.
Low noise, Low distortion as usual.
Reduced single ended ground related issue possibilities.
分线器有没有推荐的??这种多路输出直接分线器就行了为啥要前级?需要单独去做的是多个输出去选择。
yes@JohnYang1997 Is the chassis/form factor of pre90 identical size to D90/A90?
Subs should have low pass by themselves. If not, get a different sub...
It is not going to be out for a number of months, probably not even this year. Better asking for an update in the new year if nothing is announced then.Any update on preamp? @JohnYang1997
