Topping Pre90 Review (preamplifier)
Spine chillin entry. Should l stay or should l sell it (?) Armir dinnae say anything about this glitch. Same as the Fosi top pre amp ? Which l bought too
Keep them. The "glitch" is no problem if you don't clip the output, which should never happen at home.
Thanks, it s a marvellous piece of audio equipment. I have also the Fosi Audio ZP3-rather good. I happen to run all XLR, from pre amp to electronic Xover ,to power amps, Purify and Hypex, Armir s fault got me broke eheheheheheheheheheh
Thanks, it s a marvellous piece of audio equipment. I have also the Fosi Audio ZP3-rather good. I happen to run all XLR, from pre amp to electronic Xover ,to power amps, Purify and Hypex, ...
I also have a FOSI ZP3 as a part of our multimedia connectivity. Though, I find the Topping E2x2 OTG to be a better, all-around, more-versatile performer, which is part of my upstairs server/desktop system. Both of these have been stop-gap measures, while waiting (and wishing) for a ADAC unit. Like a hybrid analog/digital preAmp. Fully featuring multiple analog ADC, with multiple digital DAC.
Users can choose to BYOEQ, be it digitall thru multiple USB I/Os and/or at either analog ends (active speakers, x-overs, etc.)
Look at --for example-- at the great ADC performance of the new Topping KB22 keyboard, acting as an AudioInterface.
...Armir s fault got me broke eheheheheheheheheheh
@amirm will get me broke when such a hybrid analog/digital audio device is FINALLY introduced from the 'fellows' across the Pacific.
I'll end-up pawning off a lot of hand-me-down audio devices, he forced me to purchase, over the years! :rolleyes:
Not sure if 'glitch' is the right word. But most people don't know that balanced lines are supposed to be done in a certain way.
Also, the type of the cable itself causes confusion.
Why are there BOTH a shield and conductor 1 if they are both means to be connected to the case? In fact, I am puzzled myself. A 2-pole + shielding cable should be sufficient then.
The shield is pin 1. There are two conductors- the first one goes to pin 2 and the other to pin 3. These conductors carry the signal and the shield should have nothing to do with them. None of the conductors, including the shield are to be tied to the case.
There are single-ended cables that are as you describe. The idea there is that the shield is only tied at one end, so that its shielding only and is not required to complete the circuit of the signal path.
I'm considering the Pre90. The input impedance thing, not sure how this will affect my inputs? I have an SPL phono stage, an old Kenwood tuner, an RME Dac for inputs. Is this 2000 ohm input impedance spec gonna mess with the sound of this unit for me?
You'd really need to know the output impedance of those components to get a basic idea of how they'd interact. And keep in mind it's the XLR input impedance that's on the lowish side. RCA input Z is 10k as I recall so more reasonable and forgiving.
I keep mine for the great input/output level options, C1/2 compare functions and the EXT90 that I use. Also have another EXT90 with the A90D setup
