Topping Pre90 Review (preamplifier)
I sit 4 Meters away from mine - it works.
If yours is not working return it.
You have a genuinely huge listening space!
I sit nearly three meters away. It works, but needs too much effort to aim it correctly for it to work. Installing the IR repeater device helped, but it's still not nearly as easy to use as other common device remotes that take no thinking whatsoever to work.
The remote control is unacceptable, but far from 'non working'.
What made a huge difference for me was switching to discrete presses (one press per step), as suggested by another member here, instead of holding the button down continuously until reaching the desired volume. Using it this way completely changed my experience and I would say I had almost no frustrations since then.
As for the clicking sounds: I do hear the mechanical relay clicks from the unit itself when adjusting volume, which is expected behavior. However, those clicks are not transmitted through the speakers in my case. I’ve used this device for about three years now, and across three different pairs of speakers, I’ve never had relay noise come through the audio signal.
I did not have the relay sounds coming out through the speakers either.
it usually does, when one points perfectly straight. I installed a cheap IR repeated and now it works as good as it gets for an IR remote.
Another problem are the "clicks."
When you go volume up or down, you can hear CLICK CLICK CLICK CLICK.
The problem is, those clicks are also being heard through the speakers.
Ok, this is *very* weird. Something must be broken in the device, since one should not hear the clicks through the speakers.
You don't hear it with music, but try playing 40Hz test tone and start changing the pre-amps volume at the same time. In my case, I do hear "clicks" through the speaker.
I think I would expect some amount of clicking through the speaker when changing volume. Even if the relays are very fast, there will either be a brief silence or a small splat.
Same here.
It sounds like a splat :) Got me scared a bit, I was testing 40Hz output under power and the "splats" came out rather loud through the mids and tweeters.
I hope they don't burn the tweeters.
Impulses, unless they tear something or often relatively benign since they don't convey a lot of power.
I suspect what's happening is that we are all very unable to hear 40Hz, so you turn the gain up and then hear broadband splats, usually masked by music.
Ok, I will try. However, if it does not break anything, then it us harmless.
Amazing pre indeed, I rushed to buy it after the test here. Cheap and very very good.
Pretty hard to justify any other SS pre out there over the Topping in terms of performance. I guess one could gripe about connectivity,
One gripe is the balanced output does not support AES48. That means ground loops are possible (which can increase IMD even if an obvious buzz isn't present) and long interconnections are likely not. In a proper balanced connection, ground is ignored (hence ground loop immunity), which is to say that the output of pin2 of the XLR is generated with respect to pin3 of the XLR rather than ground (pin1).
In the Topping, like many other balanced line products for home use, the output of either pin2 or pin3 is created with respect to ground. IOW its really just two single-ended outputs which are out of phase with each other.
This means the single-ended output is 6dB less than the balanced so you know the output is non-compliant; if it were compliant with AES 48 the output levels would be the same single-ended or balanced. If you think of an output transformer with a simple secondary winding having only 2 connections, you can see that grounding one side of the transformer will not change the output Voltage at all.
If this is clear as mud, check out this web page: https://www.ranecommercial.com/legacy/note110.html
To drive a balanced line properly you can use an output transformer (with no center tap) and there's a solid state circuit that can float in the way required (That Semiconductor makes stuff for that). Simply using dual opamps, even though they can drive 600 Ohms no worries, does not mean its an AES48 compliant output.
Yup. I like that the extender was made an option rather than trying to shoehorn more into the pre itself.
If you look at interior shots, 'shoehorn' is a bit of a stretch. It seems to be a spacious layout despite its size.
I also experienced difficulty with using the remote and my main unit failed after about a years use, this is only the second equipment failure in my 40+ years in audio. Needless to say, I’m disappointed with Topping.
Spine chillin entry. Should l stay or should l sell it (?) Armir dinnae say anything about this glitch. Same as the Fosi top pre amp ? Which l bought too
