Guys, I'm not getting this, please help me to understand. I totally agree that this is an amazing, amazing preamp -- the specs are incredible. But the modern thinking is, unless u have a phonograph where u need to elevate the signal to line level, why have a preamp at all? Isn't the new way to simply run yr DAC straight into your amp (with volume control) and be done with it? As great as this little unit is, it has no phono preamp and has no headphone out (which, you know, would be kinda nice). I'm a newer member, so if my thinking on this is wrong, feel free to correct me. Thanks!
Two reasons come to mind. The most common one is that DAC-controlled volume can limit the dynamic range as the volume drops (ESS used to host a powerpoint presentation on this, but
the link is broken now). The basic premise is the signal itself goes down in amplitude but the noise floor coming out of the DAC is fixed. That’s versus an analog preamp where the noise floor drops at the same time with the signal. Relatedly, the best SINAD from a DAC is usually at full output. So if you were really anal retentive about things, you’d run, say, a D90SE fixed at full 0db volume output, taking advantage of everything it has to give, then use the Pre90 as your analog volume control into a power amp. But plenty of people are perfectly happy running quality DACs straight into the power amp.
Another more niche reason would be systems with digital room correction. Just throwing numbers out there, if your DSP (whether manual PEQ or Dirac filter, etc) is set to boost some frequencies by 10db, then you’ll need to run your DAC at -10db to provide the headroom for the boost so that the output doesn’t clip. But realistically that means sending an overall lower strength signal out of the DAC since the vast majority of frequencies are
not being boosted by 10db in the DSP. In that case, run your DAC at -10db for the headroom then cleanly add the gain back in with the Pre90. This is basically my case, but even then I don’t find I need the extra gain back with the combination of my power amp gain, speaker sensitivity, and SPL requirements.
