Regarding the volume control, i know the unit makes a clicking sound when adjusting volume, due to the relays. But is that clicking sound audible through the speakers.
Lets see how it compares to my current DIY preamp with it's £ 5 car stereo potentiometer for volume control....
Using the RCA input from my phono stage >XLR out, I have to increase the volume from -20dB from my M400 DAC to around -08dB for my phono stage.
So I suspect the output is just pseudo balanced.
Regarding the relay clicks, you cannot avoid them, they are not that intrusive and how often are you changing volume, once set just enjoy the 'extra' music.
Bought mine from HiFiGo £453 to the UK inclusive.
How does the Pre90 works with your phono stage so far?
And what is your phono preamp?
So this wouldn't go well with Denafrips Ares II DAC ? RCA Un balanced 1,200 ohms ?https://www.audiosciencereview.com/...reamplifier-extender.17635/page-3#post-572778
seems like 2kohm, so from common internet hifi principles those old high output impedance dacs would get FR strongly affected by that
Did you end up picking the Pre 90 up ?A lot of people are missing the point that this is a reference level product. Asking them to worsen their performance so that it’s more flexible with poorly designed products isn’t fair. Use this preamp with a modern high end amplifier and DAC for state of the art sound. That’s it’s use case and what it was designed around. I get that people have devices they’d like to use with it, but in order to do so it makes this product worse in performance and cost. I don’t see that making sense at this level.
I’m picking one up because I was actually in the market for a stereo preamp, nearly went for tubes, but I’ll try this first and check back.
Do you know what the Impedance level is for RCA ? I may have read it was 10k ohm can this be confirmed. The thing is this Pre 90 cost $950 Australian and im stretching my budget. But on the other hand say something like the Denfrips HESTIA that is 60k ohms Input Impedance / 400 ohms output impedance this would ideally be a better fit but it cost $1,450. (if i can save $500 for something that wont really affect my sound that bad id be happy) I seem to be reading mixed responses to stay away from the Pre 90.Actually, "should not be used with less than 10kOhm", and pre90 is 1.44kOhm? That is not ideal then, you will notice a voltage drop. But besides that there should in theory not be any bad side effect on sound.
Input impedance of pre90 RCA is higher, you could try Ares 2 RCA into Pre90 and see if it's any "better". But like the others said, pre90 can yield a slight SNR benefit due to the superb pre-amp performance, but will that be audible? Maybe not...
If Topping have done odd implementations to game snaid charts I’d also be concerned about cut corners on the pre amp output to the power ampPlease check this thread, ohno. The output impedance is discussed quite a bit:
https://www.audiosciencereview.com/...re90-ext90-preamplifier-extender.17635/page-7
"There's no standard. And it works fine with majority of devices. Also it's only the balanced input that has 2kohm. Single ended is 10k which is what majority of modern devices use.
Also there's simply no reason for me to design for every use case possible. It's meaningless. And it's not beneficial. "
Furthermore, it looks like the Hestia's input impedance is 20k Ohm
https://shenzhenaudio.com/products/...s-a-full-discrete-true-balanced-pre-amplifier
Cut corners, like what? This isn't exactly a budget device anymore. Not sure what you mean. Pre amp output to power amp looks 100% fine..I’d also be concerned about cut corners on the pre amp output to the power amp
Hello @JinshanGreetings, newb here, just wondering if there have been any reports of failures like with the L30 as they seem to use the same NFCA module (also the A90).
Regards from downunder, J
Welcome Aboard @Jinshan.Greetings, newb here, just wondering if there have been any reports of failures like with the L30 as they seem to use the same NFCA module (also the A90).
