Of course it's true balanced...
Thanks. I use 1m RCA cables to monos and 1m speaker cables so pretty short. From DAC to Pre I intend to buy a cable as short as possible, like 0.5m max. Of course if preamp improoves sth. in my case (so far I prefer direct DAC-monos connection).With monoblock amplifiers I assume you have fairly long cable runs and also running the signal cable parallel to the power cable.
I would use DAC > XLR >Pre > XLR >RCA Amp.
The XLR to RCA cable, ground connected at the XLR end only. The pre is transparent whichever way you use it. I use Van Damme Quad core cable and Neutric XLR connectors.
This company or similar will make any cable you like.
https://www.designacable.com/musici...le-xlr-lead-pair-van-damme-neutrik-cable.html
Yes. So far it was the best directly (I tried expensive preamps) but maybe with pre90 will bring improovement. From the reviews they say it is transparent and remain the character of the source. The improovement is in sounstage and dynamics. And there is great PRAT which is important for me. I will test pre90 to decide whether to buy it or not.@DHT845
Cant you use your DAC directly into your poweramps ?
Just wondering your need about a preamp at all ?
@DHT845
Don't understand what you are saying.Most of Poweramps only have single XLR or RCA input only and binding posts to speaker. That's why Pre-Amps come into play, it's like a selector with multiple sources (digital or analog). Unless your DAC is direct connect to integrated amplifier (Pre & power amp in our chassis).
In this case Topping Pre90 is pure analog pre-amp. If your external DAC comes with multiple digital/analog input (Coaxial/USB/RCA/XLR) and single analog output (RCA/XLR) , you can connect the analog to PowerAmp direct with RCA interconnect (single ended) or XLR interconnect (balanced)
In short, this Pre90 is designed for owners with multiple analogue sources like CD player, Network media player, turntable, etc. If you have only single source, forget about the preamp.Don't understand what you are saying.
My point is that if you just have a DAC as source, you can drive your amp directly with it and do not need any preamp at all.
Nothing more.
What is the point of using XLR->RCA cable from the Pre90? I have great RCA cable for my SE amp.I would use DAC > XLR >Pre > XLR >RCA Amp.
In short, this Pre90 is designed for owners with multiple analogue sources If you have only single source, forget about the preamp.
Right sir, two days ago, I tried to set -6dB on D90 Pre mode with XLR out to A90 with pre-amp mode at medium gain and full volume pot, I could sensed loosing little dynamic and punch (not loudness) from my speaker has been degraded compare to D90 Pure DAC mode.Though as I pointed out in post 490 that if you have to attenuate your DAC you could be loosing performance. So purely as an analogue gain control it could have benefits.
Was the test properly done? Double blind and with levels matched to 0.1dB? If not, this will be expectation bias influencing your perception. When I have done similar tests, I cannot hear a difference when the test is properly conducted.Right sir, two days ago, I tried to set -6dB on D90 Pre mode with XLR out to A90 with pre-amp mode at medium gain and full volume pot, I could sensed loosing little dynamic and punch (not loudness) from my speaker has been degraded compare to D90 Pure DAC mode.
I expected that DAC with max out and Accu with -12dB analog gain will sound better than DAC -12dB and Accu set on 0db Gain. And I was surprised that not.
