Um, Benchmark?
HPA4 paired with DAC3 paired with HDMI switch with audio extractor. Three remotes. Costs a lot.
^^^ Or ADI?
Very limited inputs. So e.g. ADI2 + Pre90 + HDMI switch with audio extractor. More affordable. Yet three remotes.
Trinnov (yes, but breaks the bank).
The Pre/Pros comes close to what I am looking for:
Anthem AVM70 or 90, Anthem STR Pre (with reservations), Yamaha CX-A5200, NAD 658 (with HDMI expansion), NAD M17v2i, NAD M12.
But they have severe performance issues or they cost a fortune. Take any of that as base, reduce design to stereo, remove DTS/DD etc. codecs (just plain PCM/DSD), remove room correction, add AES/EBU, add USB (optional)...
Basically make a good and transparent Digital / Analog source selector with volume control and remote with say 3xRCA inputs, 1xXLR Stereo input, 2xS/PDIF optical, 1xS/PDIF coax, 4xHDMI inputs and 1xHDMI output (with ARC support), 1xUSB (optional), 1xAES/EBU input and 1xAES/EBU output, 1xStereo XLR output. Actually I don't care much if it only does ADC or DAC to all the sources and just have either digital (AES/EBU) or analog (XLR output).
If you need EQ you just connect that to say ADI-2. If you need room correction, just connect that to MiniDSP DDRC, DSpeaker Antimode or use Genelec SAM monitors, and so on. I might be the the only one dreaming of such, :-(.
