PA5 was a single chip, but PA7/PA7 Plus has a dual chip configuration.
You did not use the Ti EVM board in mono and XLR settings like civilized people?Don’t think I am aware of any dual TPA325x implementations before this one, so this is going to be first one!
my $10 bet is that it would measure as well, if not slightly better than PA5Hopefully Amir has it measured very soon
Yes, but if there is a good explanation why the PA5 was failing and how they solve the problem, it could help.my $10 bet is that it would measure as well, if not slightly better than PA5
however the concern for most potential buyers will be how reliable it is.
Yep,an official statement about the cause of failure along with the (better rock-solid) fix would definitely help to slowly re-establish some trust.Yes, but if there is a good explanation why the PA5 was failing and how they solve the problem, it could help.
I think the explanation is here in the previous pages.
...My guess is that the PA7 uses the TPA3251 and the PA7 Plus uses the TPA3255 amplifier chip.
Based on his experience with the PA5, the PA7/PA7 Plus seems to have a structure in which the heat from the amplifier chip is dissipated to the case through a large aluminum block so that the heat does not accumulate inside the case.
the selling point of PA7 and PA5 previously is that it's extremely clean for an amp. yes it does not really matter as NC252 has ~95dB SINAD, but PA7 likely has 20dB better SINAD, so if you are pursuing the "cleanest" possible sound on a budget.With tax included the PA7 is the same price as the audiophonics Hypex NC252 amp.
The Hypex has more power, no external power supply and is probably way more reliable than the topping.
I would‘ve considered getting the Topping at 350€ but not for 500€.
oops. just lost my (imaginary) $10 betI only have the PA7 Plus and post the review of it just now: https://www.audiosciencereview.com/forum/index.php?threads/topping-pa7-plus-amplifier-review.43932/
Why not?I hesitated to jump on the PA5 train and glad I did. Not even tempted this round.
