@Firespeed so the Node was with the Hegel and not the PA5?
Just trying to make sure it’s Apples -> Apples
I agree USB will more than likely result in a better signal vs S/PDIF/coax. I run the Node 2i>D90 SE>Schitt Freya+ and it sounds great. Once I did hook up my laptop to the D90 SE>Freya+ and it did sound different but it wasn't level matched so was difficulty to compare as I didn't have a quick method to switch back and forth. By all accounts it shouldn't sound different if using an outboard DAC but...Hello Laserjock,
Speakers = JMR Folia Jubile (technical description PDF embedded here)
The sub is connected through E50's RCA output.
Hello Rottmannash,
Yes, exactly ! It's much better ! Amir has tested both connection type :
Also, i never used the onboard DAC on the Node 2i because it has been tested by amir....: "[...] Resulting SINAD though (signal over noise and distortion) is not great at just 88 dB. This is well short of the dynamic range of the CD so the statement that the unit supports high-resolution, 24-bit playback is moot [...] " (link).
You're right but my old ASUS Laptop costed me nothing, has a battery and offers me the same services : Spotify connect, stream my own library stored on my NAS and provide me access to all the internet radios) without depending on a proprietary brand (Volumio OS is linux based, Debian).
$2 bet it will not happen. they will continue releasing new models as if nothing has happened. sure, they might have learned a lesson or two, and might have made improvements internally, but they for sure will not change their "business model"Perhaps Topping will stop releasing new models every few months and focus more on reliability testing
PA7 should give a hint if any lessons have been learnt$2 bet it will not happen. they will continue releasing new models as if nothing has happened. sure, they might have learned a lesson or two, and might have made improvements internally, but they for sure will not change their "business model"
I love Topping products and own a few. I am waiting for PA5 monoblock version without volume. They release plenty of models but sadly lack any pure power amps versions to fit their pre 90.PA7 should give a hint if any lessons have been learnt
I think it's more likely PA7 will allow monoblock mode.I love Topping products and own a few. I am waiting for PA5 monoblock version without volume. They release plenty of models but sadly lack any pure power amps versions to fit their pre 90.
No. You add a bit of noise (a few worse dB in SINAD) but I doubt you can hear it, at allSorry if this has been cover here, but I need to know if using an RCA OUT (of the dac) TO A XLR IN to the PA5 cable adapter will effect the sound and volume. and if so is it a different voltage getting through … I am thinking of using 2 to bi amp my linkwitz minI speakers through the dsp
thank you
Some talk about the expected PA7, but I haven't seen anything official yet.Any updates on a successor or a MK2 version? Looking at the sinad/price value the PA5 is by far the best power amp still.
I am looking for some amps for turning a passive speaker into active but I need about 3 affordable stereo amps and this is mostly only possible with the PA5 or similar.
I'd use Hypex Fusion Plate Amps: https://www.lautsprechershop.de/hifi/hypex_fusion_amp_en.htmI am looking for some amps for turning a passive speaker into active but I need about 3 affordable stereo amps and this is mostly only possible with the PA5 or similar.
I need four way DSP and those max out at 3I'd use Hypex Fusion Plate Amps: https://www.lautsprechershop.de/hifi/hypex_fusion_amp_en.htm
Keeps it nice and tidy.
Active passive hybrid. Passive filters between T/M.I need four way DSP and those max out at 3
I would get two of these (for example), $75 each:I need four way DSP and those max out at 3
Could MiniDSP Flex 8 help there? There are DSP processors and with far more chenels but not measured hire only sometimes mentioned so I won't talk about those as I don't really know their capability/performance.I need four way DSP and those max out at 3
Yes, a Flex Eight would work great.Could MiniDSP Flex 8 help there? There are DSP processors and with far more chenels but not measured hire only sometimes mentioned so I won't talk about those as I don't really know their capability/performance.
