TheWalkman
- Joined
- Jan 9, 2020
- Messages
- 385
- Likes
- 1,012
(I can hear the first click under foot already but I will proceed with this post anyway....)
My PA 5 finally arrived Saturday after a two week journey from China. The Topping E50 had already arrived as well as some TRS cables from Amazon.
I hooked things up Saturday with the enthusiasm of a twelve year old on Christmas morning.
I've now had two days of listening and here are my thoughts.
The amp and DAC are connected to a Raspberry Pi W2 with a microUSB to USB B cable and a Sangean HD20 FM receiver with a co-ax and optical cables. (I had the cables on hand so why not. BTW, no difference in sound between the co-ax and optical that I can tell.)
The amp is connected to a pair of Elac Reference DBR62 speakers. 12g, braided, copper wire connecting the speakers.
Prior to Saturday, I was switching between an Aiyima 04 and 07 amps powered by a Mean Well 36 V, 7A power brick (GST 220A36-R78). Full disclosure, I have 1612 op amps in both the Aiyimas.
Completely subjective observations
The PA 5 sounds good. Very crisp, clean sound.
- Power: Though there has been doubt that it has enough power to drive the Elacs - quoting Amir from his Elac review, "So you better have a beefy amplifier to drive this speaker." the PA5 (and the Aiyimas) drives these speakers quite well.
- Having to deal with the TRS cables is a pain in the neck.
- When in idle mode, the case is slightly warm to the touch. (By comparison, the Aiyimas seem to be room temperature even when cranked up.)
- Sounds great
Do I like the set-up? Absolutely. Is it and end-game configuration? I haven't closed my Visa account just yet.
Recommendations
Would I recommend the Topping and DAC? I would, but only if you have the spare cash and want to know that you have a small system that specs out in the ethereal test zones of ASR reviews.
If you can't rationalize/ justify/ get the wife to let you drop three K on a Benchmark to know you have the biggest, baddest, kick-butt config there is, this isn't a bad runner-up, particularly if you're not worried about impressing the neighbors with how loud you can crank the music, or your buddies at how cool your $20K stereo set-up looks.
The Porsche GT3 factor just doesn't play with the Topping config.
However, if you're just getting into audiophilia or your budget is more modest, go with an Aiyima 04 or 07 with the Mean Well Power supply and a cheap RCA A-B-C selector switch for input. (For some reason - subjective- I like the sound of the 04 over the 07 but it's subtle (or imaginary).) Attach a Rasberry Pi streamer to your configutation and you're rocking.
Total spend on the Aiyimas: about $125. With the Topping, and cables, I'm at around $625. The Topping is a very nice system but not worth the extra $500 IMHO. If my budget were tight, I'd recommend putting the $500 into better speakers like the Elacs (which, btw, I am infatuated with) instead.
My .02.
(Let me take this opportunity to don my Nomex fire suit for some protection from the flames that will, I know, soon be coming my way!)
- Sounds great
Recommendations
My .02.
