Topping PA5 Review (Amplifier)
Billy Budapest
The Topping PA5 will be fine. According to Amir's LS50 Meta review (see link below), its distortion level at 96 dB SPL is already quite high. That's 31 W (at the 4 ohm nominal impedance) input. Therefore the PA5 has sufficient power to drive the LS50 Meta to its maximum usable SPL.
In my wife’s home office system, she is driving a pair of LS50’s with a 60wpc Amazon Echo Link Amp and it has more than enough power.
restorer-john
From the photos posted, I would say it is NOT a genuine Alps. I heave neither seen nor googled the same genuine Alps. And my printed Alps catalogue does not know it as well.
We know Alps will make, and have made just about any pot/switch combination a manufacturer wants. Consider they used to make a vast range of concentric, multi gang pots of the same size/format for car audio- for many decades. That's why we have that size- it was created for the car-audio market by Alps (Alpine).
The caps I just don't know if they are genuine or not. Nichicon has changed so much recently I cannot be sure.
But here are some genuine random picked Nichicon UFGs from my Mouser sourced stock. Notice the vent crimp stamp. It is much finer and ends before going under the sleeve.
The pattern on the top, it's precision and the moulding of the base are all specific, and unique to each capacitor manufacturer. It's one of the ways to determine the vast number of Chinese fakes being sold.
Billy Budapest
Looks like Topping better check its parts suppliers because although the two bigger caps marked Nichicon have vent stamps that look the same as above, the small caps don’t seem to have any vents! Maybe they aren’t at risk of blowing up, though, and don’t need venting.
restorer-john
The small value capacitors don't have vents. That's normal.
SylphAudio
Philippines
Here's what I can see (attached pics)
1) Softstart switch
2,3,4,5) Codaca CSCF2012 series (CSCF2012-100MC), this is smaller than SER291X series of coilcraft inductors, but just right for the application
6) Single power supply for housekeeping
7) 4 Input coupling caps for TPA3255 inputs, another 4 input coupling caps on the buffer frontend inputs
44pin probably is TPA3255 since the voltage is 38V, components like OC_ADJ 22K ohm resistor is on pin 7, FREQ_ADJ(600kHz) 10K ohm is on pin 8, etc..
Engineering efforts that were made here are on the PCB layout itself as well as the PFFB section on the input. It uses multilayer PCB which is more expensive.
Cost cutting is done on the housekeeping power supply, he can easily use dual supply for the opamps. But using dual supply can add significant cost on BOM.
Here's a comparison with my Sylph-D400 100W 8ohms / 200W 4ohms / 400W 2 ohms. With passive PFFB from TI notes, it can only get -97dB THD+N on 10W 4ohms.
I believe the next Topping PA amp will have a similar power output.
gvl
SoCal
Are there any components in this amp that command 3x price over the PA3? It’s a rhetorical question, no need to answer. Topping is becoming greedy, I’m voting against this trend with my wallet or rather by not using it.
gvl
SoCal
I think the price for the parts is just right, if you will DIY one module and recreate this from scratch, most probably you will arrive at a similar price.
Ok, so what's in this amp that's not in their own PA3 that triples the price?
Bruce Morgen
Whatever it is, the result is considerably more power and vastly better SINAD -- in fact, the PA3's SINAD is closer to the dirt-cheap Aiyima A07's than to the PA5's superb number. That said, I take your point -- perhaps the fabled "point of diminishing returns" now lives at the A07's sub-$100 USD price point when it comes to power amps.
voodooless
Netherlands
See here for a good summary:
BoredErica
USA
What am I reading right now LOL
SylphAudio
Philippines
TPA3255 alone is already 8USD to 13USD each, more than x3 the price of the one used in PA3.
Inductors are more expensive, multilayer PCB is more expensive, SOTA opamps in the buffer section costs more. Small bump in the price of BOM hurts very much in manufacturing costs.
+the cost of potting epoxy and sanding off the parts.. JK haha
You gotta give incentive to the designer so that he'll continue making the best creations.
0bs3rv3r
$250 is more money.
They are not selling parts, they are selling a damn fine amplifier. Market determines the price, usually. If you are right, then they won't sell many. My guess is that they will sell heaps however.
gvl
SoCal
Did post #1084 not answer it?
I didn't read the whole thread, so thanks for pointing to that. However XRK is based in DC, so his assessment can be a bit skewed considering Topping is a fully Chinese operation.
gvl
SoCal
They will likely sell many, this doesn't change the fact it's expensive for what it is.
