Topping PA5 II Stereo Amplifier Review
Rate this stereo amplifier:
    Votes: 18 4.5%
    Votes: 22 5.5%
    Votes: 110 27.4%
    Votes: 251 62.6%
Hi folks!
Just a reminder to keep this thread on topic and take the rest to other threads or direct messaging please. :)
Why do you understand sighted listening? Is that what you understand? I didn't mention anything about sighted listening.
Because you didn't mention blind listening.
What is sighted listening for you?
Listening where you don't know which of the alternatives you are listening to.
The resolution of the final perceived sound is not only SNR. I explained in a previous post. Even the room can downgrade the resolution of the perceived sound.
No, you explained what you mean with the term. It seems your own private meaning of the word.
That is the point though. Amps don't do that. They pretty much universally have ruler flat frequency response, low output impedance, and low distortion.
That's plain nonsense as a blanket statement. A lot of class D amps have a very poor frequency response with complex loads. With difficult to drive speakers, that can be several dB variation across the frequency band. I have difficult to drive speakers and have measured several different amps.
Class AB amps are generally very well behaved. Good class D implementations (e.g. Hypex, Purifi, ICEpower, good tpa325x PFFB implementations like PA5, ...) are also very flat.
Iam not affected by visuals, brands or whatever else.
Yes, you are - just like all other human beings are. Information from our sense are modified by our perceptive biases. It is happening all the time, we cant' stop it from happening, and even when we know how and when it happens we still can't stop it.
It is simply how our senses work.
It is why in all areas of science when human perception is tested, controlled blind testing is used. Without that it is impossible to know if what you are declaring as "different" is actually in the sound reaching your ears - or created in your unconscious brain by your perceptive biases.
So your talk of knowing how to do proper testing, and having the right equipment for it, is just an illustration that you don't.
Yes, you are right - I sort of glossed over the cheaper class D's without good PFFB, because it is not really important to the point I was making.
Because even then - your 1 or 2 dB (or even 3 or 4) load dependency is small compared with room effects that can easily be +/- 10dB or more.
And have you ever taken a measurement of the frequency response of an amp, and found it reacts perfectly with your speaker to cancel out room modes and cancellations? Of course you haven't.
So the main point of my post, that amps don't "cover" a speaker's harshness is still valid. Even with the load dependent amps - where my ruler flat frequency response statement is not so accurate with some speakers. They are still not able to "synergise" with speakers to correct bad room interactions - or even bad speaker responses.
So the main point of my post, that amps don't "cover" a speaker s harshness is still valid. Even with the load dependent amps - where my ruler flat frequency response statement is not so accurate - with some speakers - they are not able to "synergise" with speakers to correct bad room interactions - or even bad speaker responses.
Yeah. Amps with unflat frequency response get measured and called out for their frequency response variations here. Your statement isn't nonsense at all, doubly so since I have never seen a Class D amp with a FR that could mask or somehow mitigate harshness.
Here's my tiny PA5II Plus embarrassing my Rega Eliit-r today. I've had it a couple of years now and it normally powers my cheap office speakers. Never really impressed me in the past with other setups, maybe a speaker matching thing? Anyway, I have some really nice KLH Model Threes now and it's sure as hell rocking those! Let's just say, this setup has made me seriously evaluate not only my setup, but my whole hifi philosophy. Don't get me wrong, I've had a few class D amps, from my first smsl A300, to the Topping PA7 Plus (got way to hot so let it go), to my Nord Hypex NC252MP which I never felt gave me the detail I wanted. The PA5II is incredibly detailed and "atriculate", with decent bass. This post probably confirms suspitions of a few people anyway, but anyone reading this that's new to the hobby and on a budget - unless you have really hard to drive speakers in a large room then something like this may be all you need for an amp.
These two phenomena should not be mixed and do not result in the same subjective effect.
Boredcarrot,
Wish my PA5 II had a few more features. I see all the new Glitter, room correction, BT6, sub out, and a few others.
But none of the newer unit match the measured performance. At least in the same price range.
Going to rig up a downstairs listening space. Guess the PA5 II will get back in use.
Can anyone help - can I plug an unbalanced TS (not balanced TRS) cable into the balanced TRS input of this amp? @solderdude @staticV3 @Jazigo ?
Reason is I have two unbalanced sources, and I already have this amp.
I can flick the BAL and SE switch on front of amp, to switch the 2 sources and i don't need to buy anything new.
But I don't want to cause damage by connecting unbal TS cable into balanced TRS input
How your cables are wired makes a difference. If you have single ended RCA on the source the TS connector should be straightforward.
I used a source for a long time with TRS output. It was designed to handle TS and TRS cabling.
Yes you can, but you will lose all CMRR on the Amp's input.
A better method is a TRS cable where both Cold and GND (R and S) are tied to the RCA/Aux GND. That will preserve CMRR.
I use a pair of these RCA to TS adapters when I want to use the TRS balanced input for a second set of RCA interconnects and it works fine.
I've found RCA to XLR cables in the past but hard to find RCA to TRS
Other option is to find a XLR to TRS adapter, to make Topping amp input XLR.
And there are plenty of RCA to XLR cables around even on Amazon. Just hard to find RCA to TRS mono
Theres heaps of RCA to TS, but I can't see any RCA to TRS
Need mono, not stereo like this:
The good thing with these adapters is that one can easily flip the polarity and when TRS output to RCA input is used.
One can even do the same trick when the input is TRS but the other RCA has to be shorted with an RCA (which is shorted).
Which adapter are you referring to? This one?
I need mono but does that just mean I use one of the RCA inputs of this adapter instead of both?
Yes. For RCA ==> TRS, use Left RCA (the one connected to TIP of the jack) and the Right RCA (the one connected to RING) should be shorted. If you have TS input instead of TRS, the shorting of the unused RCA is not needed.
