Thank you. Would you say the same of the 3e Audio A5? If so, which would you recommend between the two?If not clipping the PA5 will sound the same as your ncore.
Agree with @antcollinet about the PA5 II. The 3e A5 will also sound the same (given the same constraints).Thank you. Would you say the same of the 3e Audio A5? If so, which would you recommend between the two?
Thank you -- have you seen any measurements of it yet? Do we know what is under the hood?In case you haven't seen it, Topping has recently released an amplifier which appears functionally almost identical to the PA5 II, but is less money:
'Topping’s new amplifier - Mini300' https://www.audiosciencereview.com/forum/index.php?threads/topping’s-new-amplifier-mini300.67036/
Thanks.Agree with @antcollinet about the PA5 II. The 3e A5 will also sound the same (given the same constraints).
Choose on features, aesthetics and - probably the deciding factor - the warranty/return policy of the sellers near you. I don't think anything will go wrong, but if it does then having to ship something back to China is a pain.
Off topic, if I wanted to sell a pa5 ii plus is there a specific space to sell in this forum?
Yes, the same.Thank you. Would you say the same of the 3e Audio A5? If so, which would you recommend between the two?
The PA5 II and the A5se each use one TPA3251 driver, while the A5 uses two.Thanks.
Question: is the PA5 ii a dual 3251 or a single? There's not a lot of information, but the info I can find suggests it's a single.
If so, would that make it more comparable to the 3e Audio A5se? And then the A5 would be a step up in sound quality?
Thanks for the reply. Should one then expect equal sound quality between the A5se and A5 when using 4ohm or 8ohm loads? (Aside from the extra 10W output power in the A5)The PA5 II and the A5se each use one TPA3251 driver, while the A5 uses two.
The advantage of the A5 with two TPA3251 drivers is its ability to handle 2-ohm loads, making it suitable for speakers with a minimum impedance below 4 ohms.
You shouldn't expect any difference in sound quality.
The crosstalk of the A5 is marginally better, presumably due to the two TPA3251 chips, but it's also excellent with the PA5 II and A5se, and no worse than with the NCore amplifiers previously measured on ASR.Thanks for the reply. Should one then expect equal sound quality between the A5se and A5 when using 4ohm or 8ohm loads? (Aside from the extra 10W output power in the A5)
Wouldn't there be some advantage to dual chips in crosstalk between channels, or some other advantage?
I am wondering about this PA5 II distortion+noise graph below. For me, the high frequencies of violins in their upper registers in classical music (often labeled sparkle and air) is a key part of my listening experience. I understand this tends to be in the 8kHz-12kHz region or even higher. The PA5 II distortion+noise at high frequencies shown below looks potentially troublesome in those registers.If not clipping the PA5 will sound the same as your ncore.
See here:I am wondering about this PA5 II distortion+noise graph below. For me, the high frequencies of violins in their upper registers in classical music (often labeled sparkle and air) is a key part of my listening experience. I understand this tends to be in the 8kHz-12kHz region or even higher. The PA5 II distortion+noise at high frequencies shown below looks potentially troublesome in those registers.
I'm not looking to win measuring contests, I'm looking to enjoy the music. I was pleased with my departed Channel Islands dual ncore architecture amp. For its replacement, would I be better served by something frequency independent like the Topping B100, also copied below?
Thank you. Very interesting thread. My takeaway is that, due to the spectral distribution of musical loads, for a given total output power, the amplifier only sends 5% of that output power through the tweeter at 5kHz, 2.5% of the power @10kHz, and 1% of the power @ 15Khz. (Assuming it scales linearly from your 400W example in post #6 in that thread).See here:
Is SINAD around 5-15 KHz relevant?
I’m trying to build some active 3-way bookshelves. At this point, I need to decide for amp selection for my high frequency >2.5 KHz. I love Hypex products and will be powering the low end and midrange with hypex modules. I’m a bit hesitant about the tweeter amplification. Most newer class D...www.audiosciencereview.com
No. Distortion at 15 kHz is not audible - at any level - as the first distortion components are at 30 kHz.Could -75dB vs. -80dB THD+N @ 15Khz be an audible difference in treble reproduction between the two amps?
Ah ha! That's why it's helpful to know what you're talking about.No. Distortion at 15 kHz is not audible - at any level - as the first distortion components are at 30 kHz.
The noise component is stimulus frequency agnostic and most accurately represented by Amir's DR/SNR measurements at the beginning of his reviews.What about the noise component?
Yeah as the harmonics move outside of the measurement bandwidth, the graphs become a bit funky.Am I understanding correctly?
