Videoteque73
- Joined
- Jan 16, 2022
- Messages
- 29
- Likes
- 55
I have it paired with a Wiim Ultra and it’s a match made in heaven!
Likely very sharp clipping behavior above 0.3%, hence no appreciable power gain as you go from 1% to 10.Why is it that at 4Ω, 100W, the PA5II's THD+N is equal to both 10% and 1%?
This is due to the weaker power supply of the non plus version.View attachment 477634
Why is it that at 4Ω, 100W, the PA5II's THD+N is equal to both 10% and 1%? Is this a quantum superposition? Does quantum collapse occur during listening, like Schrödinger's cat, where we only know what's happening at the moment we hear?
It depends of the peak listening level. Without this information the question cannot be answered.May I ask if the pa5ii is sufficient to drive the polkr200 at a distance of 2.4 meters
Pardon for the question.
Can this pa5 II have a good matching with my Polk r100?
(86dB sensitivity, recommended amplifier power of 30-150W, and an 8 Ohm nominal impedance that drops to 3.6 Ohms minimum.)
65 - 75 dbIt depends of the peak listening level. Without this information the question cannot be answered.
That's virtually nothing, and the usual level certain people listen to with their 2x5W tube amps.65 - 75 db
Some listen to more than 100dB (C) SPL with such ampsThat's virtually nothing, and the usual level certain people listen to with their 2x5W tube amps.
If sound neutral is ok, but I hope not dry@Lasker
Well, as stated just above, it depends on your usual listening level of favor.
If you like to listen to music very loud you'll probably need a 2 X TPA3255 PFFB amp with a big PSU.
Topping PA-5 II and 3E Audio A5 amp are the best TPA3251 implementations.
Topping PA-5II plus version measured gives 53 watts at 8 Ohms at 0,1% distortion (Archimago review).
Though Topping doesn't state which TPA325x chip is inside the PA-5II, the bigger PSU is still 38 volts which is the maximum allowed voltage for TPA3251.
PA-7II/plus with allegedly TPA3255 inside, has a 52 volts PSU!!!
3E audio A7 stereo (2x TPA3255 PFFB) is a nice option. (one of the best implementations of the chip out there)
2x FOSI V3 mono (TPA3255 PFFB) if you're on a tighter budget. Slightly worse SINAD though...
I have the PA-5 II plus and it's neutral sounding. If your speakers are treble-heavy or if you like warm mids and bass, the PA-5II is not for you. You'll need equalisation.
A lot of people perceive accurate and transparent as "dry". A bit like people who are used to a lot of salt in their food, and feel it is bland without it.If sound neutral is ok, but I hope not dry
For example, I'm not a fan of tube sound; I think I can distinguish between a dry and a neutral sound. Anyway, I just ordered the PA5, I hope I like it.A lot of people perceive accurate and transparent as "dry". A bit like people who are used to a lot of salt in their food, and feel it is bland without it.
What, in your view, is the difference between "dry" and "neutral"?For example, I'm not a fan of tube sound; I think I can distinguish between a dry and a neutral sound. Anyway, I just ordered the PA5, I hope I like it.
After 25 years of listening, I don't think I need to explain it.What, in your view, is the difference between "dry" and "neutral"?
