Bleib
- Joined
- May 13, 2021
- Messages
- 4,008
- Likes
- 10,123
Yesis possible connect the topping to a dac with balanced out?
but topping doesnt have the classic balanced out
TRS is balanced. One can connect from XLR to TRS, just buy the right cablesbut topping doesnt have the classic balanced out
so is better connect in balanced?TRS is balanced. One can connect from XLR to TRS, just buy the right cables
Or TRS to TRS, it's then fully balanced
Slightly better, audible...noso is better connect in balanced?
xlr-trs is not fully balanced?
Yes, I connected my SMSL DL300 to Topping PA5 II Black with a Dual TRS 6.35mm to 3 Pin XLR Female Balanced Cable. Fully balanced connection.is possible connect the topping to a dac with balanced out?
what is the advantage? i heard that in connections between 2-3 meters the result is the same as rca-rcaYes, I connected my SMSL DL300 to Topping PA5 II Black with a Dual TRS 6.35mm to 3 Pin XLR Female Balanced Cable. Fully balanced connection.
Avoidance of ground loops.what is the advantage? i heard that in connections between 2-3 meters the result is the same as rca-rca
With a balanced connection, the N5532 input operational amplifier, which is needed to convert the signal from the RCA inputs, is excluded from the audio signal path, since the TPA3251 amplifier chip uses a balanced input according to the datasheet. All parameters of the audio path are better with a balanced connection: THD+N is lower, Dynamic Range is higher, especially noticeable is the greater Сhannels Crosstalk.what is the advantage? i heard that in connections between 2-3 meters the result is the same as rca-rca
If you're good at soldering, you can also use a Mean Well HRP-150/N/N3 with 36 volts, for example. These power supplies allow you to adjust the voltage, and you can set it to 38 volts.I've blown the 38 volt power supply that comes with the PA5 II.
Over here in UK 38 volt power supplies seem strangely difficult to buy. Could i use a slightly different voltage.
I have three pa5 II in total, could i use one of the 38v power supply to power two amps by soldering an extra cable
Thanks
Which is best between simply running a RCA to XLR cable, and having instead RCA plugs at amp side plus a operational amplifier as in this implementation from Topping? Convenience for the user? The previous PA5 in fact had balanced only inputs.With a balanced connection, the N5532 input operational amplifier, which is needed to convert the signal from the RCA inputs, is excluded from the audio signal path, since the TPA3251 amplifier chip uses a balanced input according to the datasheet. All parameters of the audio path are better with a balanced connection: THD+N is lower, Dynamic Range is higher, especially noticeable is the greater Сhannels Crosstalk.
That sounds odd. You can drive a balanced (differential) input from an unbalanced source without any problems, no op-amp needed. Other way around is a different matter.With a balanced connection, the N5532 input operational amplifier, which is needed to convert the signal from the RCA inputs, is excluded from the audio signal path, since the TPA3251 amplifier chip uses a balanced input according to the datasheet.
Less channel crosstalk is actually better.All parameters of the audio path are better with a balanced connection: THD+N is lower, Dynamic Range is higher, especially noticeable is the greater Сhannels Crosstalk.
So i couldn't run two amps off the one power supplyIf you're good at soldering, you can also use a Mean Well HRP-150/N/N3 with 36 volts, for example. These power supplies allow you to adjust the voltage, and you can set it to 38 volts.
The HRP N3 series is one of the best power supplies for audio amplifiers. It delivers up to 350% power for short periods, with the 150-watt version delivering up to 525 watts for 5 seconds.
You can, of course, also use the cable from your defective power supply and only crimp the connectors for the Mean Well.
-106 dB on Balance input less than -90 bB on RCA input (above meant a larger negative value in dB)Less channel crosstalk is actually better.
OK, a larger negative value means less crosstalk.-106 dB on Balance input less than -90 bB on RCA input (above meant a larger negative value in dB)
Just wondering why they did that, as that opamp isn't needed. As I wrote, there is no problem (in theory or practice) with driving a differential, balanced input from an unbalanced output.This is in theory, but in fact wiith a balanced connection, the N5532 input operational amplifier excluded from the audio signal path, since the TPA3251 amplifier chip uses a balanced input according to the datasheet by default.
As far as I understand this circuit is implemented in all amplifiers based on TPA3251 and TPA3255.Just wondering why they did that, as that opamp isn't needed. As I wrote, there is no problem (in theory or practice) with driving a differential, balanced input from an unbalanced output.
Why? Maybe to provide additional gain? Higher input impedance?This circuit is implemented in all amplifiers based on TPA3251 and TPA3255.
