Topping PA5 II Stereo Amplifier Review
Rate this stereo amplifier:
    Votes: 18 4.5%
    Votes: 22 5.5%
    Votes: 110 27.4%
    Votes: 251 62.6%
Well if you exchange an OpAmp and that leads to the Amp objectively measuring "worse" afterwards but sounding better in your subjective opinion, then the change is still worth it, or not?
If it objectively measures the same afterwards it should not be worth the hassle. I guess.
Sure, but these people aren't talking about adding coloration.
The idea about putting "fast" capacitors in parallel with electrolytics is to filter out more high frequency noise and thereby improving the performance of said gear.
They insist on claiming that they have the ability to do these improvements on already extremely high performing amplifiers and verify them reliably by ear. And that's just... hard to believe.
Hi guys! Could you please suggest if this amp will work with wharfedale evo 4.4? I have aiyima a08pro now but I didn't test it yet, awaiting for my wharfedale to arrive... Meanwhile I thought about Topping pa 5 or pa 5 plus, but the seller told me they won't be enough and I should take pa 7... So I am a bit confused... What would you suggest for this wharfedale? To stay with my aiyima, to have a look at topping or anything else?
Hello :)
Your dealer wasn't too 'greedy' because he could have advised you to buy two like that (LOL) ->
Wharfedale recommends a 30 to 200W amplifier, the TOPPING PA5 should be enough except maybe if you want to do sound reinforcement for discotheques or concert halls.
Regards ;)
Of course it does. Do you even know how loud 1W is?
Depends on speaker efficiency and room size.
But yeah, I can't help snickering a bit when we are charging our EV, and my girlfriend asks me whether we should turn off the car stereo to make the charge go faster.
I just bought the Topping PA5 II amplifier. I had been following the discussion and reading other info about this amp. Knowing the more recently (last couple of years) in quality and spec improvements from this chi-fi company, I knew I couldn't go wrong. I performed a rather significant upgrade to my computer workstation - where I spend a lot of time - and after that was all in place I decided, why not go for a total overhaul of the audio as well! I want to improve the audio as this space was also going to morph into a little NFL listening area as well. Being close up to the speakers, allows you to hear better the nuances of the sound. I had been listening to a TV soundbar (Bose), mainly while using flight simulator, so I knew this upgrade would encompass more separate components I would have to make room for. :)
It all started with purchasing a pair of speakers, I had heard about, that got excellent reviews. The Polk, Model ES15 variety. This was not a likely pair, but having 2 different sets of ELAC speakers in my main listening room (the Uni-Fi UB5 [original ones], and the Navis powered spkrs), I wanted to try the Polks and they were the right size. Actually, a tad larger than I expected, but they do fit comfortably in my space - along side my new 43" 4K monitor. Next up was the amp. Which to choose? There are more chi-fi amps out there that it's almost next to impossible to decide which one is right for you! Amir gave the PA5 II a glowing review and even a recommendation. So, a week ago a bought one from Amazon with a 10% discount. Part of my reasoning with going the passive route was so I could do a little mixing and matching with various other amps and DACs I have (both consumer and DIY) to experiment with different sound signature and not be locked into powered speakers.
So with the speakers in place (on stands to raise them above a bit) I temporarily wired it all up, and turned it on. BTW, the DAC/streamer I was using, was a variation of my 'spider' DAC. This one is very similar to mine. This is one combination of IanCanada's PurePi powering platform (using the RPi w/ultracaps and LiFePO4 batteries), a Receiver Pi DDC, Reclocking board, a Dual ES9098Q2M DAC board, and a transformer output stage. This is very low noise (and jitter), and produces some of the quietest noise floor and is capable of transforming your digital library (roon) with clarity, articulation, dynamics and a richness. So, I fired it all up.
Playing a couple of my goto test tracks, the immediate think I noticed was the amount of bass these speakers can produce. It almost belies belief it was that good. It was a solid umph bass and not boomy at all. They're not backed up against a wall, so that likely helps the bass as well. Most bookshelf speakers are a bit thin in low registers, but the ES 15s performed with aplomb. All three pieces in the chain provided a very well-balanced musical presentation with - good clean mids and highs that were not shrill in the upper registers and vocals. I will say, the most important of all factors of a musical track is whether or not it was recorded well. I test my systems with high-dynamic range music, acoustic music and well-done vocals. A system such as mine will reveal the subtleties and nuance of the music - whether good or bad.
I couldn't be happier with my current implementation of gear at my NFL setup. The speakers are an absolute joy to listen to - especially when driven by a very clean and quiet source, and not adding any noise with the PA5 II little amp. DSD tracks sound so rich and detailed - oh so good.
Note;
Here's an image without the final resting place for everything, plus some extra pieces I'm not using using. Still waiting on some accessories and better speakers stands and riser shelfs to fit everything neatly. The final hook-up will likely include the Wiim Ultra pictured under the left speaker as my streamer.
The Polk bass reflex "power port" is pretty nifty. A clean, deep bass reproduction is key for perceived audio quality, and Polk knows it.
I couldn't be happier with my current implementation of gear at my NLF setup. The speakers are an absolute joy to listen to - especially when driven by a very clean and quiet source, and not adding any noise with the PA5 II little amp. DSD tracks sound so rich and detailed - oh so good.
Note;
Thank you for your report! And have much fun with your dream combination!
Please tell me what NFL is: I guess Near Field Listening?
And NLF?
You wrote „I couldn't be happier with my current implementation of gear at my NLF setup.“
A Typo or something I don’t know? Serious question, because I am from Germany and I am not familiar with all these short-cuts.
Yours,
thorsten
P.S. My main HiFi Setup is now at the end of the bed. With some pillows behind me, the listening distance is now 1.6 m
This is great. So close to the music and many room problems solved!
Note;
Not very dissimilar to mine - warning, this pic in 'room hijacked for Christmas' mode.
The PA5ii is on the right, on top of the WiiM Ultra.
The sub is out of shot, on the floor on the right.
And NLF?
Yours,
thorsten
Yes, you got it. Near Field Listening. Typo corrected.
Great gear selections and placement minds think alike. :) Now I'm playing with the proper selection and size of a couple different glass risers to house the gear. I have a longer one in my 'other' office similar to yours that has come in handy over the years and works very well to keep things organized, yet available. Sure helps to extend table-top space. I just received two different sizes and colors to see what fits best in the space along my right side/wall. See image. I like the black best, but it's a 2 inches shorter in length(14"), but roughly the same height as the clear set (16") - both about the same depth. You can find anything on Amazon. I'm still in the 'shifting around' stage as everything still isn't here yet. I'll post another pic when I have it's all finalized. Is this hobby ever all finalized? :D BTW, to other readers.... These tempered glass riser/shelves are not that expensive and are a welcome addition to desktop space or other counter tops to help keep your smaller gear organized and neat. The ones I purchased came two in a box for about $30 for the black ones and $25 for the clear.
So, how is the PA5II keeping up? Are there many reports of failure?
I have two, powered on 24/7 since 10 months. About 35-37C on top surface. No problems :).
Are the two inputs on the PA5 II completely independent of each other?
Oh. Another input and also analog .I was 1 short via my SMSL D-6S. I wanted to connect a tube buffer/preamp with vintage sweet sounding GE 5670 5* (I know , I know. It'll cripple SINAD :D )
I have the PA5 II Plus version with balanced input sensitivity of 2.6 Vrms, and I will be feeding it signal from Topping D50 III Balanced DAC. Since the D50's TRS outputs are 4 V and 5 V respectively, is it best to use just the TRS 4V as this already exceeds the amplifier's input sensitivity and may result in distortion and overloading? Or should the best route is to use the RCA 2.5 V output of the D50 instead? Thanks!
