Topping PA5 II Stereo Amplifier Review
Rate this stereo amplifier:
    Votes: 14 5.0%
    Votes: 17 6.1%
    Votes: 81 28.9%
    Votes: 168 60.0%
daniboun
France (Lyon)
A lot of amps use a 10k resistor and a capacitor as part of the input filter, do you know which is the input filter cap for the PA5 II
I dont have the PA5 II... Only the PA5
But if same as the PA5 should be exact
TheLastGerman
Hamburg, Northern Germany
Does anyone know the type of plug fitted to the power supply of the PA5 II?
daniboun
France (Lyon)
Yes ) GX12, 2 pins :
I made my own PSU for the PA5 as well )
john11
Do you know which is the input cap. They are all 220uf aluminium electrolytics around the input stage, would have thought the input cap would be a lot smaller than that and be a polypropylene film cap
anli
What is the source of the information? Such cap looks more appropriate as rectifier one for opamp power lines.
daniboun
France (Lyon)
Not sure, but try to check here, many pictures from inside :
anli
Have not noticed any signs there the caps are in signal path.
john11
Yes, the caps do look like they are for the input op amp, am wondering as amps do usually have an input filter usually consisting of a resistor and capacitor. Danioun mentioned the input impedance of the PA5 II is 10 kohms so am wondering where the input cap is
anli
All my own amps/schematics work from 0Hz (that is without capacitor in signal path). If this is the same case, why not?
daniboun
France (Lyon)
are you aware of any adaptor from this GX12 2 pin to standard DC power supply jack?
As far as I know no...
But you can make your own cable easy to do ) no need to have strong soldering skills
Roland68
Cologne, Germany
If there are electrolytic capacitors in the signal path (and that is very likely), then there will be 4 identical capacitors with approx. 10uF for DC suppression in the signal path. That's why a quad potentiometer is installed to operate the 4 signal paths.
Roland68
Cologne, Germany
TheLastGerman
john11
I checked the capacitors in question in my Pa5 II: The marked ones have a ground reference, all others do not. The latter are therefore most likely in the signal path. I am tempted to swap the unmarked ones for Nichicon Muse bipolars ... :rolleyes:
You could swap all the caps out. Try panasonic fm as replacements, these are cheap with high ripple current and low esr a favourite in the modding community. For the signal path you can't go wrong with silmic II. Try touching up the soldering joints as well. Also I cleaned both sides of my board with alcohol to remove any flux or crap left over from the manufacturing process then applied conformal coating. This protects from possible arcing if high voltage / current tracks are close and also protects from moisture.
The panasonic fm go up to 1000uf so i took out the big rubycon and replaced it with 2 x 1000uf and 1 x 100uf panasonic fm - amp sound better now, more detail
