I think it is manual switching of inputs. Sometimes these things are semi-auto when dealing with RCA/3.5mm inputs and Bluetooth.Anyone knows if the Auto on/off feature switches source if a new signal is detected ? of manual switch is still necessary ?
Use case : switching music source from PC (USB) to phone (BT) seamlessy.
If you are connected through BT, then when you wake up, shut down/restart, it should reconnect through BT again.thanks. i hope the BT wake up works well though at least
From what I can tell now having owned it for a week or so:The MX3S looks perfect for my setup I'm slowly assembling....can anyone confirm that the sub out volume is controlled? I'd like to feed an active sub, but control volume solely through the Topping remote.
Also, any feedback on whether the sub out is full range, or has a low pass filter? If filtered, is that changeable in the options?
On this model, you can select the output to be Speakers, Headphones or Speakers + Headphones with the MODE button on the remote. When the Headphones mode is selected, no sound comes out of the speakers or subwoofers. Just confirmed.I used an OG MX3 in a 2.1 setup. The subwoofer output of my MX3 remained active when I plugged headphones into the headphone jack. Can one disable the output of the subwoofer jack of the MX3s when using the headphone jack ?
Your need to cycle through the output options by double pressing the main button and select the headphone icon for headphones only.I used an OG MX3 in a 2.1 setup. The subwoofer output of my MX3 remained active when I plugged headphones into the headphone jack. Can one disable the output of the subwoofer jack of the MX3s when using the headphone jack ?
For my own uses.... I noted the MX5 cost more, and had no subwoofer/line output.. Different size/form factor, too. The Loxjie looked just as good as what I assume the MX3S will be, but the reliability issues I noted in online reviews made me wary...and thinking I'll spend the $30 more for the MX3S. (Things like USB audio or optical input stopped working after a few months, unit dead after a year or 2, etc)Do you know the differences between MX3S and MX5 and loxjie A30 ? Which one is better ?
MX3S, MX5 and Loxjie A30 (links to manufacturers' pages) all use the same MA12070 amplifier chip and claim similar performance and output power. They all have external power bricks.Do you know the differences between MX3S and MX5 and loxjie A30 ? Which one is better ?
The Loxjie uses the ESS only for digital input, not for USB. As a USB DAC, it uses the limited Realtek ALC40. See also https://www.audiosciencereview.com/...nput-sound-worse-than-analog-in-solved.39731/The three amplifiers use different DAC chips: the Loxjie has the ESS ES9023; the MX3S uses the AK4377 (but is limited in functionality by passing through the QCC3040 controller); the MX5 uses the ES9018. Only the MX5 can play DSD audio.
Thanks for this very complete answerMX3S, MX5 and Loxjie A30 (links to manufacturers' pages) all use the same MA12070 amplifier chip and claim similar performance and output power. They all have external power bricks.
The MX3S and A30 have subwoofer output; the MX5 does not.
The MX5 has a balanced input; the other two do not.
On the Loxjie A30, you can't connect both a coaxial digital input and an unbalanced analogue input simultaneously. The Topping amplifiers have separate connectors.
Loxjie make no claims about their headphone amp. Topping's specs claim the headphone amp on the MX5 is more powerful and has lower THD+N than the one on the MX3S.
The Loxjie is a graphite colour, whereas the Topping amplifiers are available in black or silver.
The Loxjie has a matrix display which probably means more intuitive menus, but things like the volume are shown in very small digits. The Topping amplifiers have simpler segment displays but show everything in nice big digits.
Which is better depends on which features are important to you.
How can you estimate that when you haven't measured anything.Oh in one discipline the Loxjie A30 wins hands down and that is volume. It can get MUCH louder then the Topping.
