Topping Mini 300 Amplifier Review
Rate this amplifier:
    Votes: 3 0.9%
    Votes: 12 3.5%
    Votes: 58 16.8%
    Votes: 272 78.8%
I’ve not noticed pops with my Mini 300s and I’ve got 4 of them in my multi channel setup.
I do leave my on all the time……..
Mine has no audible channel imbalance and does not emit any audible sound when turning on and off via the front switch.
The pops I've mentioned are when the amp is powering on/off.
Do you happen to have any audio recordings with a mic placed very close to the speakers?
I have the PA5 II version of this amplifier circuit and there is no noise anywhere on it or its psu. The OP's noise source is not the amplifier.
You might be conflating two different discussions.
Here's another piece of audio equipment I've purchased based on ASR reviews and recommendations that I ended up returning. I was sincerely hoping Class D amplification would be more agreeable to my old ears, but no dice. Guess I'll just have to keep listening to my old tube amps.
This amp doesnt have a sound. Not sure what one would not like about it. Perhaps your tube amp has a rolled off response or distortion you prefer.
Would be curious to know what speakers they have.
I currently have vintage Klipsch KG-4s with upgraded Crites crossovers.
For the record, I've had the same issue before with the NAD C3050 and Wharfedale Diamond towers.
There's just something about Class D amplification that really messes with my hearing.
Might also have something to do with having Tinnitus from my time in the service.
Yes, tubes are certainly rolled off at the top, but I've never had a problem with Class AB transistor amplification either.
I guess my ears are just a mess...
I agree with you; cheap Class D amplifiers lack dynamics and sound tinny and harsh in the high frequencies and upper-mids at higher volumes.
I'm going to assume neither of you has done these comparisons properly controlled and blind. In which case by far most likely is that your perceptions are being influenced by your perceptive biases.
Class D does not have a sound. If the device measures well, they will sound the same as any other amp that measures well, if they are not being driven into clipping**. At least as far as the sound reaching your ears is concerned. What your biases do in the wetware between your ears is another matter.
(or the frequency response is not disturbed by load dependency with extreme speakers for those that don't have PFFB - but if that is the case, A) it is not well measuring B) EQ can eliminate it)
Its all in your head really.
Correct you are!
Nothing. The only reason I bought the Topping Mini 300 is because of all the glowing reviews here.
And you bought it with no further expectations? Well, it's cheap, so why not.
It's just that if you prefer an amp that has a clear sonic signature due to the distortion it creates, you cannot really have expected "better sound to your ears" based on a review that confirms incredibly low distortion figures, can you?
Exactly. Figured I'd give it a roll. Didn't work out. Oh well.
As far as the popping issue I have with my Mini 300, is there anything that I can test to see if I can narrow down the cause of the issue? I know I can eliminate any input sources because it will happen even when the only thing connected to the amp is a pair of passive speakers, and I can eliminate my environment since I tested the amp in a completely different location.
I'm wondering if there's anything I can place in between the amp and the wall outlet or if it would be worth testing the speaker outputs with a multimeter (I have one, but would need some guidance on how to correctly set the meter to take any readings)?
If the popping sound occurs even when no RCA or TRS cables are connected—while using passive speakers—then it is either an inherent issue with the device or a local grounding problem (one does not rule out the other).
