You might attenuate the Mini output back down to line-level. But I'm not at all sure what that achieves with a powered speaker.Can this be used with a powered subwoofer like a speedwoofer?
Previous measurements show around 7w power usage when idle or low levels. It's a small amp so this seems normal.mine can get fairly warm when playing at very low volumes, counterintuitively
To be fair, mine lives on a perforated metal stand. So, it gets plenty of airflow.mine can get fairly warm when playing at very low volumes, counterintuitively
You can make a 2.1 setup with the Mini300 and an active subwoofer, only if the Subwoofer has High Level/Speaker Level inputs that explicitly support Class D (floating) speaker terminals.Can this be used with a powered subwoofer like a speedwoofer?
This one is probably the way to go for not much more and more power tooCan this be used with a powered subwoofer like a speedwoofer?
www.audiosciencereview.com
It's better to leave subwoofer management to a capable DAC/pre-amp/streaming pre-amp anyway. Trying to match a subwoofer handling the low pass filter and a power amp handling the high pass filter is rather fiddly and limited. Trying to do the same with a power amp with no high pass filter is even more limited and hardly worth the effort, at least in my opinion.Can this be used with a powered subwoofer like a speedwoofer?
Maybe Amir got a cherry-picked unit. My new one (TP747) has a popping noise after power-up and channel imbalance at low volume. I can’t measure whether it’s also present at higher volumes. I’m a bit disappointed.No channel imbalance was measured in the review.
I have two Mini300 amps. Neither of them exhibit the behaviour you cited (popping noise at power-up, channel imbalance).Maybe Amir got a cherry-picked unit. My new one (TP747) has a popping noise after power-up and channel imbalance at low volume. I can’t measure whether it’s also present at higher volumes. I’m a bit disappointed.
One thing I just noticed: even when I turn the volume knob all the way down to minimum, I can still hear music coming from the speakers.
Source: PC → Topping D30 DAC > RCA > Mini 300
Hi, I've tried to search this thread (and the 'net in general) for an answer, but the terms are too ambiguous - I'm wondering how noisy the amp box itself (and its external PSU) are. Not talking about the signal on the speaker leads (so dutifully measured in earlier posts), but sound emitted from the amp housing and powerbrick. I could be more lenient towards the PSU as it can be relocated, but I don't ever want to hear an amp when I have nothing playing back. I'm vexed by the 60hz transformer hum from my current amp.
Very much aware this is not easy to measure quantitatively - need anechoic chamber, measurement mic, test at various loads / orientations etc. But I'd be happy with a subjective assesment from current owners. Thanks !
Just wanted to share a quick update on my setup. Running a Behringer UMC204HD via balanced outputs into the Topping Mini300 amp made a massive difference.I have two Mini300 amps. Neither of them exhibit the behaviour you cited (popping noise at power-up, channel imbalance).
It completely solved the low-volume channel imbalance issue I was having before.
However, I've noticed a tiny click/pop sound after power on. But it´s not a big deal.
Edit: when powered off, a louder pop could be heard. At first I thought it was structure-borne noise, but it isn't. Regardless of whether it's SE or BAL.
If your source has a trigger out, try that. My 5v trigger is working perfectly with the Mini's 12v in.So either the unit itself has a defect or there's something environmental causing it to happen.
I'm using a 12V trigger to power my Mini300s on/off. Since there isn't a TRIGGER OUT to facilitate daisy-chaining, I had to use a 12V splitter.If your source has a trigger out, try that. My 5v trigger is working perfectly with the Mini's 12v in.
What is the amplitude of the input signal that is going to the amp?I have reported identical behaviour:
Topping Mini 300 Amplifier Review
*** EDIT: This post has changed significantly to incorporate information from @NTK and Topping that explained the 600 kHz signal *** In this post I will present the last of the findings from the measurements I took of the Topping Mini300 amplifier. In previous posts (here and here) I...www.audiosciencereview.com
I received a second unit today, and will test it out when I get home from work. A lot of people in this thread who own the amp say they don't hear anything, and in my conversations with Topping, they haven't been able to reproduce it on their end. So either the unit itself has a defect or there's something environmental causing it to happen.
More additional information:I don't know, and it does it even if there's nothing else connected to the amp (meaning, it's completely disconnected from my DX5 II, so there's no input signal), only passive speakers. The second/third videos in my cited post shows that there's nothing else connected to the amp.
I still have to test the new Mini 300 I received today. As mentioned, Topping has not been able to reproduce it on their end, and suggested I send it in for them to have a look.
@Dave TR3A and I had only mentioned it to Topping because with so many other people saying they don't hear anything, it seemed out of spec -- especially looking at the power on/off chart in this review.
Edit: And I think @MunizO is only the third other person to have mentioned similar behaviour to my own unit. I will report back if my new Mini 300 exhibits the same behaviour.
Edit 2:
Right away, it's a different power supply than the one I originally got. We'll see how it goes once I hook it all up. I'll even try my original unit with the newer power supply.
Edit 3:
Sadly, I must report that there is no difference in the behaviour of my two Mini 300s. Despite the difference in the power supply, the same, faint tick 2-3 seconds after powering on, and the louder pop when it is powered off still occurs.
Additional information:
I connected the PA5 II amplifier (not the Plus) I had in storage to compare. Similar behaviour, except when the PA5 II is powered off, it only emits a very, very faint tick, not a loud pop. I find it rather unlikely that I would receive two Mini 300s (purchased nearly a year apart) that had the exact same issue unless it was inherent to the amp?
