*Important note 1: Infrared thermometer is Aliexpress quality, accurate to a few degrees.
*Important note 2: I've posted photo with temps at idle below. When under load, I see maybe 2-3°C fluctuations (both up and down), not far from idle temps so did not bother to retake everything.
*Important note 3: Not at 100% volume. The pot is removed, so can only guess it's around 50%.
*Important note 4: I obviously cannot take the temps inside the chassis, so feel free to guesstimate the internal temps. I previously measured the top chassis temp at 44°C (at 27°C room temp) before turning it off and dismantling.
1. So 30°C room temp, mini 300 in the open, turned on for hours so temp stable, idle (no audio playing for more than an hour) center of heatsink is 50°C.
2. Various areas of the amp at idle. When under load, I see maybe 2-3°C fluctuations (both up and down), not far from idle temps so did not bother to retake everything:
3. Then I point a handheld fan at the board for a minute
4. I turned off the fan and measured just the center of the heatsink and the opamps
Please make your own decisions. Personally I like the product very much and hope to find simple ways to make it last. Hope the data helps others.
