Here is my not so mini review of the Mini 300 after 30 days...
My home office setup is Silent PC (w/Dirac) ->MOTU M4 -> Mini 300 -> OG KEF R3. My listening distance is about 7' from the speakers. Balanced TRS connections are used between the DAC and amp. The Mini 300 volume control is at 100% and the M4 volume control is at 50%. PC volume controls are all set to 100% with a -10dB gain reduction in the Dirac standalone processor. I do not run subs in this room.
Average SPL is ~65dBc with peaks of ~70dBc as measured with a Radio Shack SPL meter in the center of my headspace. The amp is on for roughly 12 hours per day with music playing about half that time.
My objective was to move from RCA to balanced connections to reduce noise and sell my Peachtree Nova 300 while it still has considerable resale value, as I am not using any of its many features beyond the amp itself in HTB mode. The decision was between the Buckeye NCx252MP 2 channel and the Mini 300 at 1/5 the price, 1/4 the size, and 1/3 the power.
Results are that I don't notice any difference at all except the very slight tweeter hiss and intermittent RFI noise I had with the Nova is gone. The Mini 300 keeps up just fine and sounds exactly the same while managing to use less power, run cooler, be smaller, and be quieter.
Heat has not been a problem. It sits on a console in 76F / 24C open air and barely gets warm to the touch, even after hours of use. The power supply sits on the floor under the console, where it also barely gets warm.
In terms of power, it is again fine for my use case. Since most of us actually use < 5 Watts the vast majority of the time, the old 100W at 8R rule for home audio still holds, and half that power for lower SPL in smaller rooms is perfectly suitable. Zero concerns.
As previously mentioned, I do not believe the comments claiming the Mini 300 sounds lean--at least in my use case.
KEF R3s are not the easiest speakers to drive in the bass region, and the Mini 300 sounds exactly the same across the FR as the 5.5x more powerful ICEpower
Nova 300. People claiming it sounds lean must be pushing it beyond its design limits or are victims of sight bias in which the small things must sound small, much like people believe metal dome tweeters sound metallic, silk dome tweeters sound soft and smooth, ribbons sound airy, etc.
Assuming the Mini 300 is reliable and can sit there and do amp things trouble-free for years, I am very pleased with it.
For those who may be interested, here is a graph of my right speaker showing its Dirac-corrected and slightly extended response as driven to ~75dB average by the Mini 300 during setup / testing:
Not lean.
