No. no pre-outCan the Mini be used with a pre-amp? I mean I know it's called a power amp, but the fact that it has volume control confuses me![]()
No. no pre-out
Now you are confusing me. Why would a power amp (Mini300) need a pre-out? It has a line level input, that's all it needs to be used with a pre-amp ...No. no pre-out
Yes, you could, if your plan is to deliberately add distortion to the output of the E70.So I couldn't take the Topping E70 rca out to a Fosi P3 back to the Mini rca inputs?
Is it? For a hand crafted small volume bit of audiophile jewelry maybe but what is the practicality of doing that for a mass manufactured low cost amplifier? Can you point to any examples of this being done?Has anyone measured topping amps that weren't sent by the company? Pretty standard practice to send "golden samples" to reviewers.
edit: Or do you mean that rather than send out a factory special they might just test the sample to make sure it conforms to spec before sending for review?
In the PC hardware industry where everything is also mass manufactured, CPUs & GPUs get binned and most of the time, only top tier samples get sent to reviewers. This is pretty common practice & I don't see why it couldn't happen in the Audiophile industry.
There are tolerances in all ICs, including what's in DACs & amps. Topping & other manufs could bin ICs before installing them but chances are they're just trusting their supplier that the ICs are within spec and QC happens after assembly.
It could be that Topping has super strict QC and all products that pass will measure within margin of error, but it's also possible that only golden samples get sent to reviewers and some retail samples could measure audible worse/unbalanced.
It's easy to cross reference reviews of PC hardware as there's so many reviewers running the same/similar benchmarks, but ASR is the main source of measurement data, so I'm just trying to find other sources.
The chip alone changes nothing. It's either within its spec or not. Dies from the same wafer can have different properties for sure and these in fact binned. But except from scrap (Intel invented the Celeron, so they could even sell scrap with non-functioning cache) the difference comes in the next steps: Different PCB layouts, components, cooling, firmware.In the PC hardware industry where everything is also mass manufactured, CPUs & GPUs get binned and most of the time, only top tier samples get sent to reviewers. This is pretty common practice & I don't see why it couldn't happen in the Audiophile industry.
DACs (the number of which in this product is zero) and amplifier chips (probably one) don't benefit from overlooking.There are tolerances in all ICs, including what's in DACs & amps. Topping & other manufs could bin ICs before installing them but chances are they're just trusting their supplier that the ICs are within spec and QC happens after assembly.
One such source has been pointed out.It's easy to cross reference reviews of PC hardware as there's so many reviewers running the same/similar benchmarks, but ASR is the main source of measurement data, so I'm just trying to find other sources.
Works fine for me, sounds transparent, drives my reasonably efficient speakers without issue, especially since I high-pass them at 40Hz. Feeding it with a Topping E50 II DAC. 12V trigger works perfectly from WiiM Ultra without issue. There is no real power-on noise, and there is only the very faintest power-off popping sound and I don't always even hear that. Doesn't get past luke-warm after several hours of nonstop playback at about 70dB average from 10 feet away.So... has anybody actually given this little amp a go and can they share their experience with it?
I'm very tempted!
I'm very tempted!
Your subjective perception is noted, but they would probably be more appreciated on the typical "I trust my ears" audiophile forum.I'll add...my ears are telling me it's better than the Bryston I had (B60) - it has qualities you would want improved in any Class AB...everyone wants a smoother more detailed sound right? I keep hearing things in passages of music the Bryston was incapable of, new "abilities" if you will. Stereo things, depth, any reverb/decay present in the recording.
I've been using it everyday for a couple of months now. It's fed by my E30 II and it drives my Dynaudio BM6 speakers. It replaced a Sony TA FA30ES.So... has anybody actually given this little amp a go and can they share their experience with it?
I'm very tempted!
Get a cheap DSP box, that way you can add as much coloration and distortion as you want.I've been using it everyday for a couple of months now. It's fed by my E30 II and it drives my Dynaudio BM6 speakers. It replaced a Sony TA FA30ES.
It's very nice and clean sounding, almost too perfect, to the extent that it becomes almost a bit too boring, lifeless. I find I miss the 'warmth' of the old Sony, how it was kind of 'louder' at low levels, and easier to listen to at loud levels. I don't miss the dirtier, duller highs, though.
So, I'm actually looking for a way back into class A amps again. I almost went for a 25yr old Electrocompaniet AW 60 last weekend, but it needed service, so I dropped it. Might explain the low asking price of ~$400usd.
…g-e-t-D-S-P-b-o-x…Get a cheap DSP box, that way you can add as much coloration and distortion as you want.
