Topping Mini 300 Amplifier Review
Rate this amplifier:
    Votes: 3 0.9%
    Votes: 12 3.6%
    Votes: 57 16.9%
    Votes: 266 78.7%
You can try it out first. Some 12-volt triggers also respond to 5 volts.
Alternatively, you could get an inexpensive 5-to-12-volt DC-DC converter from AliExpress.
Or you could get a 5-volt relay board and a small 12-volt switching power supply (really small), connect it to the trigger input, and use the relay board to switch the mains voltage.
Thanks @Roland68. 5V trigger worked flawlessly in the 12v Mini circuit with a little fake out as it came on within 2 seconds but took 20 minutes to turn off. Turns out the Node has a 20 min delay before the turn off trigger. Problem solved.
Amigos read this !!
Amigos read this !!
Unbalanced input only = no go (for me).
I've got my Mini 300 hooked up and running. This is my first Class D amp (also first time running balanced). The rest of system is a Bryston B60 integrated and Topping E70 Velvet.
Quickly noticed heaps of detail, MUCH smoother sound, and spaciousness. Vocals are significantly more realistic. Everything I throw at it sounds live and realistic (I'm likely generalizing Class D here). The bass delivery was more pronounced than the Bryston and needed taming. I run Audiolense + umik-1 as the final step, so I wasn't ready for a good listen until that was setup.
Thinking of using E50 II with Mini 300 but E50II has not trigger out.
I'm using it with the E50 II, but I use the WiiM Pro as the 12V trigger source. The setup gives me excellent results in terms of both sound and convenience (the E50 II features an auto-standby mode, which is very handy).
Finally received my Mini 300 today, after ordering it back around November 27/28. I'll be setting it up sometime in the next few days.
Will these properly drive the elac dbr62? I currently have an pair of dbr62 driven by the audiophonics nc252mp (2x250W) in my living room. I have another pair of dbr62 in my bedroom waiting for an amp. I was about to pull the trigger on another nc252mp, but these mini 300 are 5 times cheaper.
Looks like minimum impedance is 5 Ohm, so not a particularly difficult load. Not very sensitive tho. It pretty much depends on how loud you will be listening. Distance, size of room etc.
Given the Mini 300 is so cheap, I would be tempted to buy one and see if it has enough power for your needs. If not then upgrade to a bigger amp.
Performance-wise, it's perfectly adequate, in my experience. I can't turn the volume control past 12 o'clock with the DBR62s without it becoming unbearable in a 20 square meter room.
But you have to be careful that the Mini 300 doesn't end up in the living room ;) .
Mini 300 has no sub out.
If E50ii is paired with Mini 300.
Is it safe to do following:
[E50ii]-->TRS-->[Mini 300]-- speaker wires-->[Passive Speakers]
[E50ii]-->RCA-->[Subwoofer]
Doing the same thing with an A70 Pro. Works flawlessly.
Just use a single mono RCA cable from E50ii's RCA L (or R) to Subwoofer, right ?
Depends on the sub.
Some may sum L and R inputs internally w/o attenuation, in which case you'd lose 6dB playback volume by connecting just one.
And in rare cases the bass line of a track may be panned to one side, in which case you'd lose that bass line when you connect just the opposite channel.
Depends on your subwoofer. Mine has L/R inputs.
My subwoofer also has L/R inputs but L is labellled LFE. I connect single mono rca cable from amp's subwoofer out to LFE.
Is this wrong cabling method ?
If I am not mistaken the E50II has L/R RCA out and no sub out. So I would connect E50II L/R to sub L/R
