staticV3
- Joined
- Aug 29, 2019
- Messages
- 14,365
- Likes
- 24,784
Don't think so.Hope the source generator can be ruled out?
The APx is not immune to GND loops when using its single ended I/O.
How did you arrive at ONLY?About the noise spectrum for rca vs balanced input: I am a bit puzzled by the appearance of supply noise with rca ONLY. Hope the source generator can be ruled out?
Thanks how can you tell?I don't use trigger and mine doesn't go into standby
Be aware that the AI gets this type of answer wrong. When I was trying to find out whether the Wiim Ultra could be configured to operate trigger only when specific outputs were selected (say to power up the power amp only when the line out was selected) the AI from the search insisted that was how it operated. It isn't - not in the Wiim docs, their forum or when I stuck a meter on the trigger output and measured it.Just Googled it and this is what it says. But like you I came into my shop this morning to warm amp. I like music when I work and often forget to power down.
Thanks for both of your responses but AI referred to this Topping page (screenshot) and it clearly says it goes into standby in the ON position with no input. But like SlowJim its seems too warm for that after an hour without playing and no LED indicator change, so I'm not sure. Class D typically uses 4-10 w at idle for a 50w amp.Be aware that the AI gets this type of answer wrong. When I was trying to find out whether the Wiim Ultra could be configured to operate trigger only when specific outputs were selected (say to power up the power amp only when the line out was selected) the AI from the search insisted that was how it operated. It isn't - not in the Wiim docs, their forum or when I stuck a meter on the trigger output and measured it.
It may be the language, but what I get by the description is that the auto off is controlled by the DAC (and possibly by the DAC-PC ability to put the DAC on standby so to then trigger off the amp.Thanks for both of your responses but AI referred to this Topping page (screenshot) and it clearly says it goes into standby in the ON position with no input. But like SlowJim its seems too warm for that after an hour without playing and no LED indicator change, so I'm not sure. Class D typically uses 4-10 w at idle for a 50w amp.
No, that's definitely not what it says. I can't find anywhere that Topping writes "it goes into standby in the ON position with no input."Thanks for both of your responses but AI referred to this Topping page (screenshot) and it clearly says it goes into standby in the ON position with no input. But like SlowJim its seems too warm for that after an hour without playing and no LED indicator change, so I'm not sure. Class D typically uses 4-10 w at idle for a 50w amp.
You can try it out first. Some 12-volt triggers also respond to 5 volts.Another related question: My garage system is has laptop with Roon, an old Node N100 with a 5v trigger out, the Mini 300 amp with 12v trigger in and some 2 way speakers, so what will happen if try to trigger the 12v mini with the 5v node. Do not risk breaking anything.![]()
It clearly states "automatically powers on/off with connected DACs or devices—no manual switching needed." This only works via a trigger.
That's a typical misinterpretation of the AI.
Topping's statement refers exclusively to syncing via a 12V trigger with the new Topping DACs, which can also be controlled smartly via the new Topping Home app.
Auto Power Sync -> 12V trigger from the DAC (or other device)
Smart TRIG Control -> Control via the Home app using the DAC's 12V trigger
Thank you for the excellent review, as always.Do you want me to compare it to over $1,000 amplifier with discrete class D amplification?
That aside, those numbers are good even without those qualifiers.
What exactly do you mean?I wonder how it would work with the Wiim Ultra? It just goes into standby as far as i know. I am guessing very small power draw from the power adapter when Mini 300 is off?
The WiiM Ultra is a device that can go into sleep mode when inactive, or the user can do it.
The Mini 300 can be switched off/put into standby mode via the trigger output of the WiiM Ultra.
Sleep mode on the WiiM cuts the trigger signal so the amp shuts off.Yeah, wasn't real clear, I never shut the Ultra off really, It just goes into sleep mode. not sure if that would turn the amp off, or have to power off the ultra.
if the amp went into standby that could work.
