Topping Mini 300 Amplifier Review
Rate this amplifier:
    Votes: 2 0.6%
    Votes: 12 3.6%
    Votes: 56 17.0%
    Votes: 260 78.8%
This is a review and detailed measurements of the Topping Mini300 balanced stereo class D amplifier. It was sent to me by the company and is on sale for US $128 (normal $139).
While in the typical desktop configuration, there is a level of polish to the look and feel of the mini 300. Controls are what you need in the form of input selection, power and trigger. The amplifier gain is appropriately on the low side so I performed all of my testing at maximum volume.
Topping Mini 300 balanced stereo class D amplifier desktop back panel TRS review.jpg
It is a relief to see an external amplifier power supply that is manageable in size and weight. It is Topping branded with extensive regulatory certifications. Nicely so, it comes with a screw on, locking power connector.
Balanced inputs are provided in the form of 1/4 connectors which are quite common in pro industry. You can purchase low cost adapters to XLR or do as I did which is use a cable with 1/4 inch at one and XLR at the other.
There are generous and large vents all around and underneath which managed to keep the amplifier quite cool even after my stress tests.
Topping Mini 300 Measurements
I started with balanced inputs:
Distortion is vanishingly low and well below threshold of hearing at -122 dB. Noise sets SINAD to a very respectable 104.5 dB, comfortably landing the mini 300 in the "excellent" category of all amplifiers tested to date:
RCA input costs you a bit of dynamic range and hence SINAD as usual:
EDIT: forgot to post SNR:
Topping Mini 300 balanced stereo class D amplifier balanced SNR measurement.png
Post filter feedback seems to have been implemented resulting in almost no load dependency:
Topping Mini 300 balanced stereo class D amplifier balanced frequency response measurement.png
Crosstalk is better than average amplifier:
Topping Mini 300 balanced stereo class D amplifier balanced crosstalk measurement.png
Multitone and 19+20 kHz show the typical rise in distortion with frequency although they are still excellent for the category:
Topping Mini 300 balanced stereo class D amplifier balanced Multitone measurement.png
Topping Mini 300 balanced stereo class D amplifier balanced intermodulation stereophile 19 20 ...png
Plenty of power is on top for such a small amp and small power supply:
EDIT: graph should say 90 watts, not 104.
Topping Mini 300 balanced stereo class D amplifier balanced Power 4 measurement.png
Topping Mini 300 balanced stereo class D amplifier balanced max peak Power 4 measurement.png
Naturally you loose fair bit into 8 ohm but such a speaker impedance is rare:
Topping Mini 300 balanced stereo class D amplifier balanced Power 8 measurement.png
It was difficult to measure power at 40 Hz as the amp would go into some intermediate protection mode where it would distort but not shut down. Eventually I got a single measurement:
Getting another bite at that apple, we see the response in our sweeps vs frequency:
Topping Mini 300 balanced stereo class D amplifier balanced Power 4 distortion vs frequency me...png
I was pleasantly surprised to see the lowest power on/off noise I have ever measured and by a good bit:
Topping Mini 300 balanced stereo class D amplifier balanced Power on off noise pop static meas...png
Edit: as usual, the amp was ready to party on power up even though it dances a bit:
The Topping Mini 300 provides a polished execution with excellent implementation of class D using chip amplifier. For the cost of a single meal at a restaurant, you have a stereo amplifier that produces plenty of power yet occupies very little space. It certainly breaks the cliche that you have to spend a lot of money to get good performance.
I am happy to recommend the Topping Mini 300 stereo amplifier. It represent the category excellently, putting a smile on my face in test after test.
Specs:
  • 【Professional Balanced Class-D Design】Featuring a fully balanced amplification architecture, the TOPPING Mini300 minimizes noise and interference for a pure, distortion-free signal path—achieving professional-grade transparency and depth in a compact form.
  • 【High Power Output with Ultra-Low Distortion】Delivering up to 140W×2 @4Ω (THD+N <10%) and maintaining <0.0004% THD+N @8Ω 5W, Mini300 combines high fidelity and high power, ideal for both HiFi listening and studio monitoring applications.
  • 【Exceptional Dynamic Range and Clarity】With 124dB DNR and 124dB SNR, Mini300 preserves every subtle musical detail—allowing instruments and vocals to sound natural, lifelike, and richly layered.
  • 【Auto Power Sync with TRIG Control】The TRIG-linked power function automatically powers the amplifier on/off in sync with connected devices—making system control effortless and eliminating the need to operate multiple units individually.
  • 【Dual Input Compatibility】Supports both balanced TRS and unbalanced RCA inputs—no adapter required. Easily integrates with DACs, preamps, or audio interfaces for flexible system setups.
  • 【Quiet, Safe, and Reliable Operation】Engineered for silent startup/shutdown, and equipped with overheat and overcurrent protection, ensuring long-term reliability and zero noise during playback.
  • 【Compact and Durable Aluminum Design】Built with a CNC-machined all-aluminum chassis available in multiple finishes. Bottom and side cooling vents improve thermal efficiency while maintaining a clean, modern appearance for any desktop setup.
thanks for the badass review again, my purchase was vindicated, absolute fire amp with great pricing to match. Pretty sure it'd cost like 5x more a few years ago and like 10x more if they put it in a prettier shell
A power amp loosing one third (1/3) of its max power down low or going to protection even lower is not great in my book.
Other implementations of the same or similar chips do it just fine and they also do low loads (we don't have test here but its specs is down to 4 Ohm so would be unfair to ask for lower)
The price is unbeatable though, so... I will understand the appeal it may have to some people.
Thanks Amir!
Great performance for the price, thanks for the testing @amirm.
Manufacturer pic;
User pics, posted by @jazd in the other thread;
JSmith
thanks for the review. Title should be corrected to "Mini 300' ?
That's cheaper than my weekly groceries or a 65L tank of fuel, but it's probably all the amplifier anyone with a medium sized living room will ever need! I setup my source gear with a maximum volume limit at the point where -20dB is at 85dB in room. I forgot the value but I ended up somewhere around 70% with the Hypex nCore NC252MP. The Hypex has cost me five times as much and is a statistically worse amplifier. Congratulations Topping!
I'm going to modify a wooden radio from the 40's with modern components. I'll consider putting this amp in.
The review title says "Mini 3" - I guess "Mini 300" would be correct?
They may have been tested with larger power supplies.
