Topping MA4 Review
Nuyes
Reviewer
South Korea
Topping’s First Speaker
Topping — a brand well known for its DACs and amplifiers — has finally released a loudspeaker.
Given their strong track record of staying ahead of audio trends, I had high hopes for this one.
Interestingly, despite being designed for small spaces, the speaker has quite a deep enclosure.
This appears to be a deliberate choice, most likely to accommodate port tuning.
Frequcney Response
The overall tonal balance is quite flat.
For a 4-inch speaker, the low-end extension is impressive — reaching down to about 48.9 Hz (-6 dB) with a roll-off slope of roughly 32 dB/oct.
With the increased cabinet depth, I’m hoping for strong low-frequency performance.
Nearfield Measurements
One of the most impressive aspects is the 'port'.
Port noise is extremely well controlled and doesn’t stand out at all.
The woofer response is also very clean — nicely done!
CEA-2034
The smooth, upward-sloping directivity index (DI) is perhaps the most striking feature here.
Directivity
The radiation pattern narrows smoothly and uniformly — exactly what you’d hope for.
Topping has clearly done their homework.
Vertical directivity is also well controlled.
The lower edge of the tweeter’s waveguide appears to have been slightly shaved down to reduce the physical gap between the drivers — a small but meaningful design choice that pays off.
Beamwidth
From around 2 kHz upward, the beamwidth narrows consistently and evenly — a desirable trait for controlled directivity.
Polar Plot
The polar plot really helps visualize the speaker’s radiation behavior.
With the exception of the 10 kHz band, the speaker maintains fairly uniform energy up to ±30° off-axis.
Vertical radiation is also well-focused around the primary listening angles.
THD
The distortion pattern is quite interesting.
Across most of the woofer’s operating range, the 2nd harmonic is dominant — which is perfectly reasonable given the driver quality at this price point.
Even so, low-frequency distortion remains relatively low for a speaker of this size and class.
The tweeter, on the other hand, appears to be extremely capable.
It seems to operate well within its limits, leaving plenty of headroom.
Multitone Test
If you're hoping for a small woofer that can deliver deep bass and remain clean under complex intermodulation — that might be asking too much.
The tweeter is impressive, but the woofer still shows room for improvement.
Even after limiting the low-frequency range for retesting, the overall trend remained unchanged.
No particular anomalies were observed.
Compression Test
The original plot exceeded the standard ±3 dB range, so I re-adjusted the scale accordingly.
Overall, woofer performance is reasonable for the price — and again, the tweeter stands out as exceptionally strong.
Deviation between 2 samples
Sample-to-sample consistency looked solid.
Especially considering this is Topping’s first mass-produced loudspeaker, the results are quite respectable.
Final Thoughts​
Given Topping’s proven track record in affordable DACs and power amps, I was genuinely excited to see their take on a loudspeaker.
As expected, the design prioritizes objective performance rather than compromising for convenience — and that’s a good sign for the market.
Controlled and uniform radiation, smooth tonal balance, and impressive bass extension all add up to make this a compelling package, especially at its price point.
You can tell this speaker was developed with the CEA-2034 standard firmly in mind — which earns it extra points in my book.
However, I did notice one unfortunate issue during testing.
While playing content below 100 Hz, a clear air-leak noise was audible.
Because this kind of leakage creates random noise, it doesn't easily show up in typical THD measurements — yet it can be quite noticeable depending on the situation.
To confirm the source, I tracked down the location of the leak and placed a thin tissue over it to visually identify the airflow.
The leak was coming from the rear switch box.
With the owner’s permission, I opened up the speaker and found that the manufacturer had attempted to seal this area —
but likely due to the strong internal air pressure around the port’s resonant frequency, the solution wasn’t fully effective.
I believe Topping is well aware of this kind of problem.
But in mass production, extra costs are always a consideration — and I hope they find a reliable and cost-effective fix moving forward.
If their handling of the PA5 amplifier is any indication, I trust they’ll find a smart solution again.
After all, it’s Topping.
That’s all.
Thanks @Nuyes
What kind of a bummer it would be them releasing it knowing that air leaking issue, if they know it. Do you have the air leaking in both the speakers or did you just have only one?
Any indication how are they priced for North American market?
Thanks @Nuyes
Yes, I was able to confirm the same air leakage in both samples.
I do believe Topping has the ability to solve this issue.
Of course, the biggest challenge is likely finding a balance with manufacturing costs.
Adding a physical barrier around the switch box would probably be the most reliable fix — but also the most expensive one.
All I can do is cheer them on and hope they find a smart solution.
Did you give them listening test as well?
A few things; first is there a listed price for these speakers and second would a little bit of silicone caulk around the switch box solve the problems (and void the warranty.) Finally would a subwoofer which most small speakers benefit from reduce this problem along with reducing the distortion.
sad to see the issue about the leakage for an otherwise very good performing speaker.
as for the looks and the (odd) shape of the speaker – i really dont dig it at all.
Thanks for the great review. Good agreement with Topping's posted measurements. Seems like their "anti-resonance design" for the port works a treat.
Interesting speaker, not really practical for most people's desktop setups due to how hugely deep they are. Also the lack of any inputs besides XLR is a downer. Seems like it'd make a decent monitor for professional use as long as they can get that air leak issue sorted.
The AliExpress says "1 piece" so it is a single speaker for $450, but it is an active. So $900 for an active that plays this low. Would love to see what they could do with a "big brother" version with a 6.5" woofer, maybe for l.t. $1500? Bet the distortion numbers would be much improved.
We're now seeing speaker releases from some providers like Aiyima and Topping who revolutionized pricing in high end audio electronics. I think this bodes exceedingly well for the price of highly performant bookshelf speakers over the next couple of years. I can imagine that the producers of $3-10k high end speakers have to be getting kinda nervous about now.
Nuyes, thank you for your fine review, and your many other interesting and valuable contributions.
Anyone else on here post in the past about wondering if brands like Topping and Fosi are gonna get into speakers, I did. Lol ..Anyone in need of a business school graduate (accounting), please see my post in the jobs thread
The Topping and SMSL does suffer more QA issues than other brands. They have to stop rushing products out the door and spend more time, effort and other resources in proper QA.
Sorry, but this review qualifies as stupid and is way below ASR's usual standards. Is this a powered loudspeaker? No mention. No mention of what amplification is in the box anything about the configuration etc. That's ridiculous. In fact the entire review reads as though it is a passive loudspeaker until you see the image on the videos.
I consider the review in need of clarification, perhaps due to human error. It does contain useful information.
Topping appears to be optimizing for published measurements here rather than sound quality. Does 50 Hz response with 100%+ THD really sound better than a speaker that rolls off a little sooner with less distortion?
Nearly $900/pair is a tad pricey even for a pretty good active two-way in 2025 -- it's up against the highly-capable and widely available three-way Kali Audio IN-5 at that price point, and the (IMO amazing) IN-8v2 with its eight inch woofer is only $100 more. Another thing to keep in mind is Topping's warranty return policy -- unless that policy has changed over the past couple of years, they expect you to ship the failed product back to Shenzhen at your expense so they can "evaluate" whether the problem is covered. This is bad enough for a small item like a DAC -- I just gave up on my E30 rather than risking it flunking the evaluation -- but for something as heavy as a speaker it's totally unacceptable IMO.
If I am not mistaken, the reviewer is based out of a South Korea as such perhaps there is a minor language gap.
I don't even have to think about it and calculate the maximum level of the loudspeaker.
Actually only suitable for the absolute near field.
Nuyes does this in his spare time and has no requirements to meet, certainly not yours. I'm sure he'd appreciate constructive criticism, but yours is not very much not that. I'd thank you not to harass him with your incredibly rude comments.
This is not one of Amir's reviews, this is made by a forum member. There's a clear photo of the back of the speaker showing power and XLR in - you can use reasonable inference here.
Personally I'm very appreciative of Nuyes work and do not understand why you feel the need to personally insult someone who has done an amazing job of compiling measurements for this new speaker. If there's some additional information you want, perhaps try asking for it respectfully.
