5.2 vs 6.0 preference score is absolutely not meaningful.
I think it is important to explain the limitations of the Spinorama score rather than jumping straight to the conclusion....
The score (typically ranging from 0 to around 10) is calculated by combining several key factors measured in an anechoic chamber. It helps to estimate how human listeners would rate the speaker in a blind listening test.
The score is calculated by combining several key factors : Frequency Response Flatness / Bass Extension / Directivity Error
BUT ! It ignores the harmonic distortion, cabinet resonances, thermal compression and the room acoustics dictate reality (keep in mind that your actual room dimensions, furniture, and speaker placement will heavily alter the final sound you hear.)
Conclusion should be : the preference score is an incredible tool for filtering and comparing speakers but it is not a perfect metric )
