- Thread Starter
- #41
My listening was at 1 meter or so. I don't think half a meter is realistic.Maybe this is another entry in the computer desktop market with a listening distance of half a meter and an added sub?
I'd be curious to pop them open and have a look - my suspicion is that the vent is quite long and it's simpler and less expensive to manufacture if the vent is straight.I am sure they had their reasons but a small monitor that has more depth (288 mm) than height (255 mm) seems a very odd design choice.
T5V is also a strong showing:A bad tongue could say a typical Topping product, optimised for some score like Harman or SINAD but failing as a total in real use.
Also at 190$ it is too close to the JBL 305/6 (soon MKIII generation will be on the market) or KALI LP6 V2 which in total are a less of a compromise.
www.audiosciencereview.com
I did wonder at what distance your listening tests are done. 1 meter on all speakers, or varies with the speaker?My listening was at 1 meter or so. I don't think half a meter is realistic.
I have three setups:I did wonder at what distance your listening tests are done. 1 meter on all speakers, or varies with the speaker?
Because in a small desk, especially in Asia, width is a premium. This is why almost all PC speakers are the size of the driver. If you don't make the cabinet deep, then you have very small volume. I don't know any desk that is NOT deep enough to contain this speaker by the time you figure out the space for keyboard and screen/laptop.By the way why is it "smart" to add internal volume by adding depth to the enclosure?
I stuffed paper towels in there. While it nicely dealt with the distortion, the sound became quite flat. I liked my EQ much better, albeit with a bit more potential for distortion.What happens if you block the port with foam?
Sounds like it might be something rattling around inside leaking out of the port. Doesn't speak to particularly good build quality.I stuffed paper towels in there. While it nicely dealt with the distortion, the sound became quite flat. I liked my EQ much better, albeit with a bit more potential for distortion.
FYI, even if I just put my hand in the port the woofer rattle stops or reduces! So doesn't take much.
Oh wow. I guess MA4 mkii is soon incoming.Do you know if this point has been corrected ?
While playing content below 100 Hz, a clear air-leak noise was audible.
100% THD means the sum of all distortion products has equal amplitude to the fundamental frequency.I thought that I instinctively understood what 100% distortion meant. Then I began overthinking it, and now I’ve no idea. 100% means complete and total, so silence would be 100% distortion, surely?
What does it actually sound like? Any layman’s explanation welcomed, thank you.
That's the old LP-6. The newer one (IIRC) has a preference score of about 5.8-6. Not to mention lower distortion, etc.These have a pref score of 6.0 while the JBL 306p and Kali LP-6 each are 5.2, so within their ability range these should sound meaningfully better.
5.2 vs 6.0 preference score is absolutely not meaningful.These have a pref score of 6.0 while the JBL 306p and Kali LP-6 each are 5.2, so within their ability range these should sound meaningfully better.
