Topping MA4 Monitor Speaker Review
Rate this speaker:
    Votes: 33 16.1%
    Votes: 111 54.1%
    Votes: 51 24.9%
    Votes: 10 4.9%
This is a review, listening tests, EQ and detailed measurements of the Topping MA4 powered active monitor. It was sent to me by the company and costs US $189 each.
The MA4 compact and light. Company wisely extends the internal volume by deepening the speaker. Machined front panel exudes higher quality than otherwise ordinary wood cabinet.
I like the simplicity of the back panel:
Topping MA4 Professional Studio Monitor Speaker Active Powered back panel balanced XRL Review.jpg
Topping is best known as producing state of the art audio electronics. Can they do it with speakers? Let's find out. FYI, company has a Klippel NFS scanner.
NOTE: company send me a sample more than a year ago but was not prepared to enter the market then and asked me to hold off. I *think* they sent me a sample recently and I am not sure if the one I am testing is that one, or the earlier one. There may be some minor production changes -- I don't know.
Topping MA4 Speaker Measurements
We can see company has put its top notch measurement system to good use in producing excellent tonality:
Topping MA4 Professional Studio Monitor Speaker Active Powered anechoic frequency response mea...png
There is a tiny step down in treble response and some micro disturbance in the 500 to 2 kHz. Directivity is smooth though narrowing -- something I didn't expect given the waveguide.
Step down in treble energy impacts early window response even more:
Topping MA4 Professional Studio Monitor Speaker Active Powered early window frequency response...png
But it is balanced by on-axis so predicted in-room response looks pretty good:
Topping MA4 Professional Studio Monitor Speaker Active Powered predicted in-room frequency res...png
Near-field driver responses shows typical resonances:
Topping MA4 Professional Studio Monitor Speaker Active Powered driver frequency response measr...png
What was disappointing was power capability. I don't expect much from some a such small speaker with a 4 inch driver. But even at 81 dBSPL I could hear objectionable gurgling sound from the woofer which got worse naturally at 86 dBSPL:
Topping MA4 Professional Studio Monitor Speaker Active Powered relative THD distortion measrem...png
Topping MA4 Professional Studio Monitor Speaker Active Powered THD distortion measrements.png
We can see that bass distortion reaches 100% at 40 Hz.
Given the waveguide, I expected a more constant directivity. But it is the opposite in the way it is proportionally beaming, albeit very smoothly:
Topping MA4 Professional Studio Monitor Speaker Active Powered horizontal directivity measreme...png
Reminds me of Dr. Toole recalling the design of an Infinity speaker with similar goal and him saying it was difficult to pull off.
Vertical directivity is decently wide which is good:
Topping MA4 Professional Studio Monitor Speaker Active Powered vertical directivity measrements.png
We see resonances in waterfall graph:
Topping MA4 Professional Studio Monitor Speaker Active Powered CSD waterfall measrements.png
Finally step response:
Topping MA4 Professional Studio Monitor Speaker Active Powered Step Response measrements.png
Topping MA4 Speaker Listening Tests and EQ
First impression was a surprisingly warm and balanced sound. OK, the measurements predicted them but psychologically one expects a small speaker to sound sharp/bright. Alas, it did not take long for really bad distortion to enter the picture. Yes, I play reasonably loud but lowering the level doesn't help much until you get way too low -- below my every day listening level. The fix thankfully was simple: a high pass filter:
Topping MA4 Professional Studio Monitor Speaker Active Powered Equalization.png
I started with 50 Hz and that was good on some tracks but problem returned on others. At 60 Hz, most tracks were OK but not the Yello Till Tomorrow you see above. A synthetic rattling/gurgling sound was evident even though at first it seemed to be part of the song. Lower the volume, or plug the port and it went away. Upping the filter to 70 Hz allowed me to listen to pretty elevated levels without the distortion interfering.
With the above setting, we had a perfectly good speaker with track after track sounding very good to excellent.
I commend Topping for getting into speaker design with proper measurement system ($120K+ Klippel NFS). They seemed to have gotten the tonality and directivity right. But opted to push the speaker too low in frequency for its size and driver capability resulting in significant amount of objectionable distortion. Getting this balance right is what makes speaker design so challenging. By solving one vector but not the other, the MA4 leaves me somewhat disappointed. Fortunately the fix is simple with that high pass and I wish Topping would opt to provide this in the speaker itself -- perhaps by adding a high pass switch.
Personally I can't recommend Topping MA4 due to clearly audible distortion even at moderate levels. But you all may feel different given the reasonable cost and excellent tonality and the fact that you can fix that with a simple high pass filter.
【Precision You Can Hear】Delivers neutral, accurate and uncolored sound for reliable recording, mixing, mastering and critical listening.
【Consistent Sound On and Off Axis】Optimized directivity ensures balanced sound and accurate imaging from a wider range of listening positions.
【Clear Imaging in Real Rooms】Optimized early reflections preserve spatial accuracy and clarity, even in untreated or compact rooms.
【Opti-Wave Tweeter Waveguide】Precisely controlled dispersion and a 1.4kHz crossover deliver smoother integration, lower phase distortion and a wider sweet spot.
【Fully Balanced Analog Crossover】An all-analog signal path preserves natural dynamics and fine detail with minimal phase distortion.
【Cleaner Midrange & Flexible Placement】Anti-resonance design and a front-firing bass port deliver cleaner mids, tight bass and greater placement flexibility.
【75W Class D Bi-Amplification】Dedicated 50W + 25W amplification delivers ultra-low distortion, high dynamics and powerful, detailed sound.
Thank you for the review @amirm,
Could the internal powerAmp be partially responsible for some of these distortion products?
no vote ?
Yes,
As of now, there is no opportunity to vote on the just reviewed, Topping MA4 powered monitor
Likely an oversight, but, 'not a good look' on Election Day in the USA. ;)
Raise the port tuning to 80Hz and give it a 4th order LR filter at the same frequency, bringing it down to -6dB, then it'll integrate wonderfully with any sub and give you a decent amount of headroom. If you want to push small speakers to go low, you'll have to get deep into non linear processing e.g. what phone manufacturers are doing to avoid the distortion issues that are happening here.
At near 200 bucks this is a tough sell compared to the JBL 305P MK2 imo.
If you ever needed proof that a spin doesn't show everything, there you go.
as mentioned by Amir,
I reside in Apple's walled, 'Garden of Eden', but have read that 'up to' 200 Samsung Smart Tags can be registered to one Samsung smartphone.
Samsung is about to release in the USA a 'Smart Tag 3' and there may be good deals to be had on the 'Smart Tag 2' tracking device.
Perhaps a campaign can be started at ASR where members can send compatible Smart Tags to Amir to attach to gear to be measured. :)
Here is my take on the EQ.
Please report your findings, positive or negative!
For the score rational your journey starts here
Explanation for the sub score
The following EQs are “anechoic” EQs to get the speaker right before room integration some insight here.
If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there.
The raw data with corrected ER and PIR:
Score no EQ: 6.0
With Sub: 7.9
Spinorama with no EQ:
  • Quite a few resonances
  • Decent directivity if not quite top notch
  • Too much bass for its own good?
  • No Dynamic range compressors?
Directivity:
Better stay at tweeter height but +/-10deg looks fine
Horizontally, better toe-in the speakers by 10/15deg and have the axis crossing in front of the listening location, might help dosing the upper range. Explanation here.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable (here).
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
  • One can model the EQ with Vituixcad by using the DSP "Generic" setting with 96000Hz sampling rate.
Score no EQ: 6.0
With Sub: 7.9
Score EQ LW: 6.3
with sub: 8.5
Score EQ Score: 6.4
with sub: 8.5
Code:
Topping MA4 APO OCD EQ 96000Hz
November042026-124616
Preamp: -3.30 dB
Filter 1: ON HPQ Fc 50.3 Hz Gain 0.00 dB Q 0.86
Filter 2: ON PK Fc 102.3 Hz Gain 0.59 dB Q 2.14
Filter 3: ON PK Fc 455.6 Hz Gain -0.90 dB Q 5.99
Filter 4: ON PK Fc 825.7 Hz Gain -2.42 dB Q 1.79
Filter 5: ON PK Fc 3365.4 Hz Gain -1.76 dB Q 1.77
Filter 6: ON PK Fc 5831.0 Hz Gain -1.29 dB Q 3.89
Filter 7: ON PK Fc 4300.4 Hz Gain 3.59 dB Q 0.12
Topping MA4 APO Score EQ 96000Hz
Preamp: -2.50 dB
Filter 1: ON HPQ Fc 50.0 Hz Gain 0.00 dB Q 0.88
Filter 2: ON PK Fc 100.0 Hz Gain 0.48 dB Q 2.26
Filter 3: ON PK Fc 459.9 Hz Gain -1.18 dB Q 5.25
Filter 4: ON PK Fc 815.2 Hz Gain -2.51 dB Q 1.99
Filter 5: ON PK Fc 3401.8 Hz Gain -1.77 dB Q 1.98
Filter 6: ON PK Fc 5812.4 Hz Gain -1.30 dB Q 3.39
Filter 7: ON PK Fc 3622.4 Hz Gain 2.87 dB Q 0.13
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
No improvements?
Bonus:
Somewhat less aggressive than Amir's, but experimentation is needed...
Topping MA4 APO HP EQ 96000Hz
November042026-130743
Preamp: -2.90 dB
Filter 1: ON HPQ Fc 70.0 Hz Gain 0.00 dB Q 1.03
Filter 2: ON PK Fc 74.1 Hz Gain 0.38 dB Q 2.26
Filter 3: ON PK Fc 458.9 Hz Gain -1.15 dB Q 5.90
Filter 4: ON PK Fc 812.2 Hz Gain -2.54 dB Q 1.99
Filter 5: ON PK Fc 3401.8 Hz Gain -1.73 dB Q 1.79
Filter 6: ON PK Fc 5809.4 Hz Gain -1.30 dB Q 3.39
Filter 7: ON PK Fc 3613.9 Hz Gain 3.29 dB Q 0.13
  • Topping MA4 APO Score EQ 96000Hz.txt
  • Topping MA4 APO OCD EQ 96000Hz.txt
  • Topping MA4 APO HP EQ 96000Hz.txt
Yeh, to some extent I will accept small tonality errors I can correct with EQ to get more dynamics which I can't fix.
If it cannot do 81dB at 1M without audible distortion, it is not a serious product.
Amir,
Thank you for devoting the time to measuring earphones and three loudspeakers in the past week. :D
Fair price, bad bass distortion, easy fix with high pass filter, as shown in the review. With one or two subwoofers it could become a good speaker, except for the other ugly distortion peak at 400-500 Hz. So, not on my list, in spite of owning seven subwoofers around the house.
Erin's sample had, if anything, even worse distortion. His sample at 86dB was between 2-3% THD up to about 2khz.
Work in progress, did a quick EQ by hand.
Will be edited later, currently has a high shelf, not sure if it's worth trying to avoid it.
Edit: apart from a slightly flatter mid range this looks pretty much identical to what Maiky did.
First of all, @Maiky76, if this is a computer optimizer algorithm on your end, wow!
I doubt the differences between me and Maiky's would even be audible, no way to find out without listening tests! :D
Will leave it at that for now and thank you for sharing the EQ Maiky!
So you can contrast and compare(measured @ Thursday, Sep 3, 2026)
Also added pictures see attached files
