Topping M62 thread
Skittle8336
Has anyone had the chance to try this yet?
The specs are crazy, and nothing else in this price range comes close.
I’m really hoping they release a desktop version with similar features, because having a 4-band EQ on the inputs, a 10-band PEQ on the outputs, and 88 dB of gain is unheard of even in interfaces that cost three or four times as much.
Pre-read...
ADC SINAD - Mic inputs 1+2, 0dB gain, 48kHz, Un-weighted
Level here is 2.139 Vrms (8.8 dBu)
Same at -60dBFS
So dynamic range is >118.5dB unweigthed
More to come...
EIN @Max gain, 150 ohm, 20°C, 20Hz-20kHz
Note that EIN @60dB and even @50dB gain is identical,
so the huge 88dB gain is probably a more traditionnal gain with an additional "push" in digital domain.
Still very respectable though.
It's a completely different device.
The ADI-2 doesn't have a mic input, but it has multiple digital inputs and outputs.
It also has a lot of useful display and diagnostic tools.
It's a true Swiss knife for studio use.
The M62 is meant as a mobile interface.
Two completely different use cases.
Reactions: MAB
Hello, Rja4000!
I'm looking to replace my interface for measurements and am hoping to find something that can be used even slightly above 20 kHz.
Could you tell from your tests if the ADC and/or DAC in the M62 reach well beyond 20 kHz (using adequate sampling rates) or if they always are LP-filtered around 20 kHz?
BTW I'm used to using 48 kHz because my Mac seems happiest there, but perhaps I can coax it into working with higher sampling rates.
I really can't understand why they didn't make the line in Hi-Z... This performance is completely unheard of with mobile interfaces, all of which completely suck.
This would be a perfect High-End iRig type of device.
Have one on my desk.
Looks awesome.
Measures the same (so far).
Review is coming soon...
Looking forward to the review! Your other reviews for the UCX II and UFX III and various preamps are great and very in-depth!
Does anyone know if the M62 supports connecting instruments such as guitars? Or only MIC IN?
First video review?
Yeah, on Russian, sorry, need a translation :D
But it's a pretty good review, and you can watch the video to see how this topping works in terms of software and capabilities.
It looks great.
With the discount in Russia, you can buy it for 17,000 rubles, which is about $220.5. Not bad.
E2X2 around 152-168$.
First video review?
It looks great.
The product page states no Hi-Z input, only Mic and Line. So you'd have to use active instruments (common with bass guitars, not so common with guitars) or some sort of impedance converter like an active preamp or a transformer based DI-Box.
It's a shame really. Otherwise this product would be killer
That seems interesting, but I can imagine the hassle of a serious review given the number of features to consider...
(Many people not going to rush into doing it....)
Good luck rja4000!
Some observations regarding the use of the M62* under Linux (in my case, Debian Testing):
  • In "Mobile Mode" the M62 is displayed by default as a simple "Analog Stereo Duplex" device:
    Code:
    Topping M62 at usb-0000:2d:00.3-1.1.2.3, high speed : USB Audio
    Playback:
      Status: Stop
      Interface 1
        Altset 1
        Format: S32_LE
        Channels: 2
        Endpoint: 0x01 (1 OUT) (ASYNC)
        Rates: 44100, 48000
        Data packet interval: 125 us
        Bits: 24
        Channel map: FL FR
        Sync Endpoint: 0x81 (1 IN)
        Sync EP Interface: 1
        Sync EP Altset: 1
        Implicit Feedback Mode: No
      Interface 1
        Altset 2
        Format: S32_LE
        Channels: 2
        Rates: 44100, 48000
        Bits: 24
        Channel map: FL FR
        Sync EP Altset: 2
    Capture:
      Status: Running
        Interface = 2
        Altset = 1
        Packet Size = 56
        Momentary freq = 48000 Hz (0x6.0000)
      Interface 2
        Altset 1
        Format: S32_LE
        Channels: 2
        Endpoint: 0x82 (2 IN) (ASYNC)
        Rates: 44100, 48000
        Bits: 24
        Channel map: FL FR
  • In "Live Streaming Mode" and "Pro Audio Mode", it is displayed as a "Multi-Channel Duplex" device:
    Code:
    Playback:
      Status: Stop
      Interface 1
        Altset 1
        Format: S32_LE
        Channels: 10
        Rates: 44100, 48000, 88200, 96000
        Bits: 24
        Channel map: FL FR FC LFE RL RR FLC FRC RC SL
        Sync EP Altset: 1
      Interface 1
        Altset 2
        Format: S32_LE
        Channels: 10
        Bits: 24
        Sync EP Altset: 2
    Capture:
      Status: Stop
      Interface 2
        Altset 1
        Format: S32_LE
        Channels: 16
        Bits: 24
  • The channel assignment of the capture interface is not entirely clear here. Pipewire/Wireplumber assigns the channel names AUX0 to AUX15 to the 16 audio positions. Through trial and error, I determined the following output assignments:
    Code:
    AUX0/1 -> Analog 1/2 (IN1 [MIC1 | MIC 3.5 | MIC-HP]; IN2 [MIC2])
    AUX2/3 -> AUX IN
    AUX4/5 -> Bluetooth IN
    AUX6/7 -> Mobile IN (OTG)
    AUX8/9 -> Loopback 1/2
    AUX10/11 -> Loopback 3/4
    AUX12/13 -> Loopback 5/6
    AUX14/15 -> Loopback 7/8
Some further general notes:
  • The vendor of the USB interface is Thesycon Systemsoftware & Consulting GmbH.
  • The integrated effects/FX of M62 are only available in "Mobile Mode" and "Live Streaming Mode".
  • The 10-band PEQ for the headphone output is only available in "Pro Audio Mode".
  • The included remote control is rather unusual for Topping. It has 31 buttons. :rolleyes:
  • However, the "M Control Center" GUI application is still essential. It is required to update and fully configure the M62 (Bluetooth, power settings for OTG and USB-C ports, automatic power on/off; single/double-click of the main button). Of course, it is also needed to adjust the equalizer, use the automatic microphone gain feature, configure effects and mixers etc.
* Hardware version: V1.00; Firmware version: V87.05.45.48.37; Software version: V1.8.0
Headphones out (Load = RME ADI-2/4 Pro SE - Unbalanced - 19dBu range - Unweighted)
We get the promised 16dBu output.
Given less than ideal conditions and without weighting, we should be around the promised 115dB with A-weighting
At least, with the new version of the APx 500 Flex, I'm able to measure it 8-)
I admit I'm eager to see the rest of your observations... but I realize the difficulty given the number of features etc...!
got some time with this last night. quite a capable box though 'mobile mode' is essentially useless for mic-in as it outputs stereo but routes the mics to both otg output channels. need to go into the advanced modes and manually route channels left and right
Reactions: MAB
