A critical part of a product's success as a digital recording interface is its control software and ease of use. Is this product meant for use in a portable recording setup? How exactly is that meant to be set up? Does this device need to be connected to a laptop or smartphone to record audio? Or can it be used standalone with a USB storage drive connected?
daniboun just mentioned that there are no high impedance instrument inputs. That means if you wanted to record an electric guitar straight into this device, you'd need some kind of a preamp/buffer (a 'guitar preamp' with gain, not just an electric guitar effects pedal or a unity-gain buffer).
The product also lacks XLR inputs. That's a shame. But it does have 48V DC phantom power. That's good. I guess recordists will need to factor in the cost of acquiring XLR to TRS adapters for their existing mic cables, as microphones require XLR connectors on their end.
Another critical consideration is how well this device gets along with the dominant DAW apps out there. Does its driver play well with Pro Tools, Cubase, Audacity, Reaper, Ableton Live, GarageBand, Logic, etc?
I see there's a digital reverb included in the device. How does that sound? Is it competitive with the VST plugins available (many of them cheap or free)? If the reverb is usable then that's a plus, but that's an unnecessary feature unless the built in reverb algorithms provide a lot of control and are truly exceptional sounding. I guess adding a digital reverb is cheap and easy to do, so why not? Hopefully it's a usable feature and not just a distraction.
In addition, the product includes built in PEQ. Again, that's a feature that's covered in all the popular DAW apps. What is the intended use for this device? Is it expected that the PEQ will be used during live recording ('tracking'), instead of in the post-tracking/mixing phase?
Also, what would the Bluetooth interface be used for, in the real world? Is that both input and output, as in the designers expect users to be able to record from Bluetooth headsets? For musicians (and to me), that looks like another unnecessary feature that was cheap and easy to add on.
I don't see separate volume controls for studio monitor loudspeakers and headphones. Are those separately adjustable from this device? Or is this meant to be used with headphone monitoring only?
The ADC measurements are truly impressive, but it looks like it might lack some of the features people expect to find in a musician's home studio or portable live music recording interface. I could be wrong, though.
Necessities of a home recording studio type of AD/DA interface:
1. Balanced XLR inputs for microphones
2. 1/4" inputs for either balanced line level sources or unbalanced electric guitar/bass
3. +48V DC phantom power for condenser microphones
4. High impedance instrument input mode for recording electric guitar, bass guitar straight to the interface.
5. Monitor level control (for controlling your studio monitor loudspeaker setup separately from the line out volume level adjustment).
6. Headphone out with its own level control.
7. A good, easy-to-use app or hardware interface to switch on/off features and settings (Hi-Z/Lo-Z, phantom power, active inputs/outputs, bit depth/sample rate, etc.)
Measurements are one thing, but this device should be a tool to get something concrete done in the real world. Can it do it gracefully, with ease and flexibility? Or is this all about the glamor of the best possible measurements, with usability features compromised?
Again, I could be wrong about all of this. If I am, please clarify so I and others may know what this device can and cannot do as a musician's recording interface. Thanks.
