Roland68
You’re fixating on something that isn't actually there.Every OTG capable device I've ever come across has a single port which works with standard and OTG hosts, there is absolutely no need for two separate ports. Labelling a port as OTG implies it's use as an OTG HOST, which is confusing. Are you sure it supports concurrent USB audio inputs, that would be highly unusual?
The M62 is not a host device.
The M62 has a USB port for computers, phones, and other host devices.
It has a USB OTG port for OTG host devices.
The third USB port is strictly for charging/power supply.
A maximum of two devices can be connected to the M62; Topping also highlights this dual-host support in the manual's specifications.
When using two phones or tablets, the main device connects to the OTG port, handling the streaming or recording.
The second device, connected to the standard USB port, can handle a second stream or play background music.
This is extremely practical and useful, even if you don't happen to need it.
Just for your information: USB ICs enabling OTG peripheral functionality have existed for a long time—found in photography/video equipment, game controllers, and the like—though it remains a niche area.
