Any information on this DSP01 IC? Is this the first Topping-branded chip?
The DSP01 processor is a custom digital signal processor from Topping.
So it's a proprietary chipset from the brand
Hmm, seems I'm still confused about what OTG is. I thought it was so the device could instead be a host to other devices. If you can't use USB mass storage or audio devices on the M62, what are you supposed to plug into the OTG port?I can't actually figure out how to get this to record on my phone easily. If they could make a way to plug in a USB stick to the OTG port to record - it would make this 100x better, or a way to plug a DAC into it for two extra outputs would also make this 100x better.
It is actually self-explanatory, especially given its use as a mobile device. It isn't confusing; rather, it is a forward-looking, future-proof design.Why is there 3 USB C ports for charge, otg, and usb-c? It seems kinda confusing...
Frequency response is flat as you want it:
Flat to 10Hz is pretty good
Note that the OTG port can be set to "discharge" (i.e. charging a device from the M62) or "off" (i.e. not charging that device). The USB-C port can be set to "charge" (charging the M62 from a device, e.g. a laptop), "discharge" (charging a device from the M62), or "off" (neither charging or discharging). The charging port can only be used to charge the M62. Only one port can be used to charge the M62 at a time (either the charging port or the USB-C port, on a first connected basis). The M62 can be charging and discharging at the same time. Charging is up to 5V/2.5A (no PD), discharging is 5V/1A (no PD or PD pass-through).It is actually self-explanatory, especially given its use as a mobile device. It isn't confusing; rather, it is a forward-looking, future-proof design.
The separate charging port makes perfect sense, particularly when on the go or using the device with a phone or tablet.
The OTG port is exactly what is needed—and intended—for operation with a phone or tablet.
The standard USB port is designed for conventional computer use, but it can also be used with a computer alongside a phone or tablet, or even with a second phone or tablet, allowing for a second music source or additional recording capabilities.
It offers exactly the features one needs in a mobile device of this kind—features that many other devices, even more expensive ones, fail to provide.
The OTG port is either a digital audio-in or a digital audio-out (configurable). With the later setting, M62 should acts as any other USB digital audio host (not tested; I just received my M62...).Hmm, seems I'm still confused about what OTG is. I thought it was so the device could instead be a host to other devices. If you can't use USB mass storage or audio devices on the M62, what are you supposed to plug into the OTG port?
oops.
According to the manual, the OTG port also functions as an output.I tried plugging into the OTG port with an apple headphone dongle, E1DA headphone dongle and DX1 II and no M62 mode has any sort of sound coming out of anything through the OTG port with or without discharge on. I'd guess the OTG is just for connecting directly to phones or tablets -aka the Topping is the OTG device you connect to your phone/tablet as the 'accessory' and not the main device you can connect DAC's/etc to.
It would be amazing though if you could connect your DX1 II to the OTG port as it would then allow this to have dedicated speaker (analog or digital) outputs. With an aggregate device on a Apple Mac it can sort of work reasonably, but you can't for example use DIRAC room correction to calibrate with the M62 and aggregate DX1 II as an an output - so to calibrate your speakers you need to use the M62 headphone outputs.
They are common features in audio interfaces. They are not for recording -- that would be daft. They are for a low-latency monitor mix.I see the product includes built in PEQ and dynamics compression. Again, these are feature that are very capably covered in all the popular DAW apps and with VST plugins. These built in effects had better be excellent, or they're unnecessary duplications of functions that already exist.
Pro forum was created long after the ADC forum. So the plan would be to move the ADC reviews to it; time permitting.@amirm Why is this in the Pro Audio Forum instead of Audio Interfaces (ADC & DAC)?
You have three microphone inputs and an AUX input, after all; you just need the appropriate cables or connectors for XLR microphones or a camera.Would be nice if topping made something like this but battery or usb C powered and could connect it to a camera via 3.5mm and had multiple inputs for xlr and 3.5 lavs and mics
Would be OK if those figures were at 44.1kHz or 48kHz.As I posted elsewhere about latency being okay, but not state of the art:
Poopcasters.Indeed.
I see there is an input labelled "3.5 mic". Is this a stereo or mono mini jack?
I'm asking because there are some nice and simple mid-side stereo mic with 3.3 mm jacks. Would it be possible to test this input?
Every OTG capable device I've ever come across has a single port which works with standard and OTG hosts, there is absolutely no need for two separate ports. Labelling a port as OTG implies it's use as an OTG HOST, which is confusing. Are you sure it supports concurrent USB audio inputs, that would be highly unusual?It is actually self-explanatory, especially given its use as a mobile device. It isn't confusing; rather, it is a forward-looking, future-proof design.
