jesburger
- Joined
- Feb 15, 2023
- Messages
- 12
- Likes
- 1
Hello!
At first I wanted to snag the new Nilai stereo kit (250w per channel), but then I thought to myself this is probably way too much power for a Cornwall type speaker with 100db+ of sensitivity.
I see the Topping LA90 has amazing measurements, and much lower power. It's even a bit cheaper.
If the price difference isn't an issue, which would you guys pick? Some notes, I already have an 18 inch subwoofer that will be crossed over around 40-60hz for this system. I'm building a Cornscala Crites Audio Type B horn speaker (15 inch woofer, midrange horn, tweeter horn).
Chain is desktop PC -> Mini DSP with Dirac Live -> Power Amp - > Speakers
The room is my unfinished basement, which is also my gym. Room is about 30 feet long. I don't play ridiculous volumes, in fact I usually play medium volume when my wife is around, but I do crank it once in a while.
Thanks!
Thanks!
