So I did some multiplication and division, and came to the realization the LA90 makes no sense (it could if the power supply was rated for 84VDC / 7.5A, but it's not....)
Example 1
Bridged mono: 95 watts into 8 ohms:
95 watts and 8 ohms needs 28VAC
28VAC peaks at +40 and -40V
Since the supply is 64VDC and this is a class AB amp:
Any rating over 64 watts should be impossible... but we somehow don't have 64, we have 95!
(Yes, I know this is bridged mono, but as there's only one supply and not dual isolated, Unless there's a beefy [noiseless] boost converter inside for use when running mono.....
Example 2
There's the 4 ohm measurement showing up to 50WPC comes out clean.
2x 50WPC 4ohms: with a 100% efficient class AB amplifier, that means 7.5 amps!
Since 7.5A is available to 4 ohms, it's also available to higher impedances. That is, until impedance rises so far that sufficient voltage is no longer available for it (power then becomes voltage limited)
With 3.75A put through two 8 ohm speakers (totalling 7.5A), power would be 112.5W x2
I'll check if we have enough voltage for that.
Unfortunately no, we don't - shy two volts! So 98 watts is what we should have, not 112.5.
Side note: (though not necessarily true) with voltage being higher and current being lower (by 0.5A), this 98w through 8 ohms should be cleaner than the 50w/ 4 ohm combination.
In the review 8 ohm only reaches 36W before clipping begins though! I want 98!!
Example 3
192W / 4 ohms in bridged mode is, again, 28VAC.
28/0.71 = 40 (+40 to -40 is +80)
So the included 64VDC power supply is insufficient.
Equally important: a single 28VAC output to 4 ohms making 192W means 7A!
Remember, the adapter's rating is for just 4 amps.
And remember, too, that the amplifier isn't some obscenity. It's essentially a standard AB amplifier optimized by people who cared about the outcome (they spent time swapping out components to find the best values, in the process learning how they all interact. Also they upgraded key components to higher grade when the choice made sense. Yes, that's all it takes to make something great. Too bad most good businesses don't last... they're bought out and then change direction to the new owner's agenda, or are just shut down so someone who's was starting to lose market share can continue selling their crap.
Final note: maybe the power supply drops from 84 to 64V when in stereo mode and 8 ohm loads are detected!
Let's find out:
64 / 2 = 32
32 * 0.70707 = 22.5
22.5 - 0.5 = 22 : 0.5V from external wire and connector)
22 - 2 = 20 : 2V from external and internal droop when wave in the >14VAC
20 - 2 = 18 : 2V for keeping some distance between the signal and the rails because if they ever meet, the transistor gets stuck there (in the on position) and your amp transforms into an unnecessarily expensive, heavy, and usually unregulated, power supply. What a waste!
Obviously I'm joking about the reason... which isn't important, but if you must know it's to avoid the area of operation very likely to contain distortion in most amps.
Ok! That leaves us with 18 volts, which is 4 watts more than the 36 Amir measured. So it's settled: the power supply has MPD: the same disorder many people, especially girls, on TikTok claim to have (but don't and it's obvious because real people (and PSUs) with MPD don't have multiple personalities simultaneously conscious in one body, they take turns controlling it and are unaware of the thoughts of the others - their only clue to their existence is losing time whenever their specific personality is not at the wheel. So Topping 64V 4A has at least one alter: 84V 7.5A...
Or maybe I'm just confused about how AB amps work. People these days are throwing clots left right and centre, maybe one came my way about 470 microns thick, just the size to fit into and block the capillary giving sustenance to the 724 neurons once dedicated to AB amplifier details (now dedicated to taking up space and off-gassing toxins while necrotizing. Protein factories remain transcribing corrupt and partial instructions,
slipped in surreptitiously by psychopaths. At first, normal cellular functions persist alongside, but after time, the toxic product begins doing damage locally. Often this damage is to DNA. Usually this slowly but surely ends the cell - all processes shut down one after another until it's just a protein factory. Myocardium cells, neurons, muscles, kidney - instructions were in nano sized industrial fats designed to cross the blood brain barrier, they're everywhere. Usually when the body's own cells start making toxins, the body attacks them. Usually it isn't all or most of the body's cell types at once (respiratory virus for example is in lungs). So when your body is busy killing thousands of all of its own cell types per day for years on end, autoimmune disprders begin (when the body attacks itself). Years on end? Some have lost both parents and all grandparents already - years if lucky.
Look up US military health statistics. In 2021, the average number of all types of diseases increased by 5x. That means the total from 2016 2017 2018 2019 and 2020 was about the same as 2021. Cancer. Autoimmune. Things like MS went from 400 per year to over 2000. Guess what's happening about it
I bought one of these amps, should be arriving from Shenzhen in a few weeks as long as geopolitics doesn't get in the way... I guess if it does I won't be too concerned about the quality of my music playback, will I? Lol
