Topping have not yet published a firmware or firmware update for the LA90D, so the only way is to contact their customer support via [email protected]Good day!
Due to my stupidity, I damaged the device, I downloaded the firmware from the topping website not for LA90 Discrete, but for A90 Discrete, followed the instructions and uploaded the firmware to the device, and now the amplifier does not work. Can you tell me what can be done, where can I get the firmware for LA90 Discrete?
Please contact Topping to obtain the LA90 Discrete firmware and perform the update procedure in the same way.Good day!
WDYM by tandem? LA90 driving the left speaker and B200 the right?I wonder if it is possible to use LA90D in mono mode in tandem with B200
Yes, that's right.LA90 управляет левым динамиком, а B200 — правым?
It's possible and perfectly safe, but be aware that the LA90D in Mono and the B200 do not have the same gain.Yes, that's right.
The difference in power can be leveled out by adjusting the balance?It's possible and perfectly safe, but be aware that the LA90D in Mono and the B200 do not have the same gain.
Power dictates headroomThe difference in power can be leveled out by adjusting the balance?
The LA90D has a specified output impedance of <5mΩ in Mono mode:Is there a measured value of the damping factor for LA90 D in mono mode somewhere?
The LA90D in Mono mode can put out 280W at 4Ω:Isn't the use of LA90 D a "bottleneck" in a system with heavy speakers, which can lead to damage to equipment, such as tweeters?
I read that a low-power amplifier is worse than an amplifier with excessive power.
Thank you very much for the detailed answer! I tried to read this thread and look for information inside. But you gave all the necessary information at once.You have nothing to worry
You will be fine with single one. I have Golden ear Triton fives and I run amp on low gain, basically with music never have to go above 2PM, with games I can max it out but usually don't need to.Dear mates! I`m glad to welcome all members of this great place. I have been in the "read only" mode for a long time, but now I want to ask some question. I apologize in advance for my bad English.
I recently started using a Topping stack: DAC, preamp, power amplifier (LA90 D). I used it on desktop acoustics, everything worked great.
But now I am planning to install floor speakers DA Baltus 90. Their impedance is 4-8 ohms. The required amplifier power is indicated from 100 to 200 W. Therefore, I bought another LA90 D, to use both in mono mode.
According to the indicators, everything seems to match. But I am interested in real experience. Does anyone use LA90 D with heavy floor speakers?
I use 2 LA90D's in Mono mode in combination with a DX9 and a pair of power hungry Marten Mingus Quintet loudspeakers. This combo is working great.Dear mates! I`m glad to welcome all members of this great place. I have been in the "read only" mode for a long time, but now I want to ask some question. I apologize in advance for my bad English.
Utilice dos LA90D en modo mono, un DX9 y un par de altavoces Marten Mingus Quintet de alta potencia. Esta combinación funciona de maravilla.
La temperatura del LA90D se mantiene bastante fresca durante todo el día. La temperatura es similar a la de mi amplificador de potencia Audiophonics Nilai 500.
Uso dos LA90D en modo mono, un DX9 y un par de altavoces Marten Mingus Quintet de alta potencia. Esta combinación funciona de maravilla.
Hi! Great to hear that. I’ve got the same setup with some Dynaudio Craft, and honestly, I’m thrilled with it. I’ve also tried it with the Merlin Audio VSM and they sound amazing, and even with the legendary B&W 801 Matrix3. The Topping drives them all effortlessly; on the contrary, it keeps surprising in a good way!I use 2 LA90D's in Mono mode in combination with a DX9 and a pair of power hungry Marten Mingus Quintet loudspeakers. This combo is working great.
The temperature of the LA90D's stays rather cool during all day use. The temperature feels the same as my Audiophonics Nilai 500 power amplifier.
