Topping LA90 Discrete Amplifier Review
Rate this stereo amplifier
    Votes: 15 3.5%
    Votes: 21 4.9%
    Votes: 68 15.9%
    Votes: 324 75.7%
I would love to buy 6 of them, to be used in my 3 way electronic X overed system.
The B200 seems to be a better choice for that use case.
The problem is musical, not pure X -Y graphs, how it handles complex signals.
There is no problem. The LA90 handles complex signals flawlessly.
Here's the waveform of Amir's multitone signal:
And the LA90D's output of said waveform analyzed via FFT:
Perfect reproduction of this immensely complex signal, with impeccable timbre and timing.
Thanks you are kind and useful way over the top!!!!
I've had the following in one of my active systems for nearly a year now:
2x LA90 (both in mono mode)
2x LA90D (both in stereo mode)
2x PA7 Plus
All still working/performing perfectly. (But only switched on a few hours per week.)
Mani.
Have you compared LA90 v LA 90 D. On sound quality ?Thank you.
They both should be audibly transparent. The only concern I have is about that popping issue, hopefully that’s been revised so I can finally pick up a pair
I have the la90 for 20 months now, what popping issues !
I'm curious if a dual-mono set-up would be powerful enough to drive a Kef Reference 1 (non-meta version). I know Devialet doesn't got the best measurements here, but I'm not unhappy with how it sounds. Unfortunately, I need to some work on the house so need to get some money from selling some stuff. Devialet makes sense, as I'm not listening a lot, and I like the idea of having something without software that doesn't 'age'. (Altho, hifi software doesn't age as fast as others)
For their frequency response, the Phantom II and Phantom Reactor 600 measure well. The Phantom I has some roughness, but looks better with EQ.
I didn't see compression and harmonic distortion data, but perhaps I missed it. If they perform well in those measurements, these speakers would be very compelling.
They get fantastic measurements:
https://www.spinorama.org/?brand=Devialet&page=1
Out are you referring to their Amps?
Amp was nothing to write home about:
Yhea, I am referring to their amps :) The Expert Pro 440 in my case. I am not unhappy about them. Sure, the price may be... questionable. But they are also fine on the eye. Of course, I read the reviews here as well before buying. It's mostly that I am not listening too much, and software/embedded software within this current state of the world, is not something I like to keep sitting around and do nothing. A good non-smart amplifier may be more durable in terms of technology, and I can build a streamer myself, as programmer. Convertor boards are quite available for things like raspberry pi or like-wise stuff. Heck, even ESP32s :), and they can be much cheaper than 3000 $ upgrades of the Devialet ;-). So I save some money for my house, and have another hobby to spend some time on.
It depends on your needs. Check out the B100 review where that topic is discussed extensively for that amplifier.
Will do that for sure, thanks :)
edit:
I checked it out. Seems like it could work... there are some comments it will not work that well for the Reference Ones that I have. But this is a B100. Perhaps the B200 could do the trick. Or ... who knows, the Schiit mono blocks. And perhaps a Topping A90 pro as pre.
ShenzhenAudio(and others I presume) having 15%off sale on LA90d and B200s
On B100, too. Problem with them is that don't prepay tax to the EU like Aliexpress, Hifigo, Hifi-Express and Linsoul do. So with 19 - 21% VAT and brokerage fee, it ends up more expensive than the other players.
I will consider myself Blessed then...have not paid any tax or shipping on any of the 6 I have purchased.
Wow. Where did you have them shipped?
I have only ever ordered low value items with them that were exempt. Unlike their competitors, they don't state that VAT is included (i.e. prepaid), in fact they don't say anything about tax and duty. There are several posts here on ASR and elsewhere of people having had to pay to get their parcel.
ok, that makes sense because there is no federal VAT in the US
Of course, the new always comes. Is inevitable. But on the way rest some awesome stuff forgotten among the waves of time and the stacks of influencers, who hear for us in these days when warehouses took the place of AV gear stores.
That said, come the Sansui gear and I wonder why a could choose not to pick one of two of them on ebay for 200 or 300 bucks. Class D amplifiers are getting better each day (their design is so bland), but it is great to realize how good these vintage amplifiers sound. And getting two of them, you realize that you cannot choose just one, because each of them represents an era. The 1978 Sansui AU 317 with its tape/vinyl like sound, denser an thick with soft highs and great bass and midrange, a perfect blend with more open and refined speakers like my Paradigm Premier 200B and the Sansui A α7, from 1994, with its refined sound, with clear mids and great, smooth highs, like finely sifted flour.
They are handsome gear perfect for a 12m² room like mine with neighbors on the other side of the wall. And I confess that buying them, I can give a testimony that old pieces like me and these amplifiers can deliver good work. So, I will keep mining these precious stones and their heavy transformers while I have some good technicians here to fix them (a really easy job) and the energy efficiency hype takes its place elsewhere.
