You can combine them however you like.Is it worth it to get the E70 over the D50 III?
i'm planning to buy the L70 or A50 III as AMP.
Yup, normal indeed. Welcome to ASR!Excuse my lack of experience, but the audible click when changing the volume is normal because it's relay based, right?
Maybe same design, same look could be a point if optics matter?Can’t decide if I want e70 velvet or SMSL d400 pro to go with my SMSL h400
I would also take the D400 Pro with the H400. They are devices from the same line and generation and are coordinated with each other.Can’t decide if I want e70 velvet or SMSL d400 pro to go with my SMSL h400
firstly with the error code r5 nothing passes through and that's why it turns on protection when something doesn't work for it. Secondly even the most expensive headphones in the world you buy a second one. You have one ears and hearing for the rest of your life, start worrying about your ears and hearing. You probably don't want to imagine what will happen to you when an explosion occurs while you have headphones on your ears.Today I got r5 error code on my L70. Power cycle resolved it, but my headphones are too expensive to play around with amp that throws errors randomly.
audiosciencereview.com
What are you saying, grandson? I can't hear anymore. Buy me a battery for my hearing aid. ,Grandpa, is that you??![]()
There is a lot of evidence that DC output can also be produced by certain songs, independent of normal or headphone amplifiers.Today I got r5 error code on my L70. Power cycle resolved it, but my headphones are too expensive to play around with amp that throws errors randomly.
DC protection is a good thing - maybe try establishing there’s a problem with the amp first? Some audio has DC offset. I run into material my RME doesn’t like often enough that I’ve just turned on its DSP subsonic filter.Today I got r5 error code on my L70. Power cycle resolved it, but my headphones are too expensive to play around with amp that throws errors randomly.
in that case the L70 would simply have been overly cautious in protecting your headphones. Perhaps this is not the case with another HPA?
I would measure it,along with what comes before it (DAC,etc)Nothing was playing, the amp was off (on standby), so the amp wasn't warm or anything like that.
I've turned it on a couple of times during the day just to see if it would post again, but it didn't.
So now is it safe to use, I don't know. Maybe I'm just being too cautious.
