Audioboxer
- Joined
- Nov 16, 2022
- Messages
- 39
- Likes
- 12
After a month or so of use still really happy. No plans to change to the E50 at any point either because its MQA which always seems to disable the windows volume control. The D10b is perfect to pair with the L50 if your only need is USB audio from a PC. I know XLR is very popular but more companies shouldn't sleep on TRS, the space you gain is great for desktop use, same great power in a smaller package.
Might be frowned on by some but my AMP is just set on medium gain at 100% volume and I control volume from my keyboard knob. That being said I have read some people say windows digital audio control makes no difference to sound quality and I definitely can't notice anything. Spotify on normal volume level with a -7.5db pre-gain on Sundara's can hit 100% digital volume without discomfort on most songs (it is loud). Other sources like youtube or games can be too loud/uncomfortable at 100% in windows with the AMP volume knob maxed out.
So definitely enough power staying off high gain for Sundara's with a reasonably beefy -db pre-gain. Not sure what exactly Spotify volume normalisation at normal drops song volume db. EQ off at 100% AMP and 100% windows volume blows your eardrums lol, but Sundara's EQ soo well so I guess most people will EQ them at a PC.
