Veri
- Joined
- Feb 6, 2018
- Messages
- 9,596
- Likes
- 12,036
That is just a wrong conclusion. If you feed it less voltage and the gain is the same, the maximum output is still lower with 2V in than with 4V in. Makes total sense if you put it that way, no?It sounds like you're saying that the gain is the same regardless if single-ended (RCA) or balanced (XLR/TRS) inputs are used. Not what I expected.
