Hi thank you very much for the kind and precious advice You are very right The performance can vary from one part to anotherYou can save yourself this trouble entirely, as it provides no information at all about your own device.
All potentiometers, even from the same production batch, are different and have variations in channel balance. So, you can be lucky or unlucky with your device. These variations can occur especially at the very beginning and end of the range.
This has nothing to do with cheap or expensive, but rather a fundamental problem in potentiometer production. However, a potentiometer is the cheapest type of volume control, and truly high-quality ones have long since ceased to be manufactured. But you can measure it yourself.
this part must be very cheap considering the price of the unit i guess that also the tiny size is not helping
thanks a lot again May i ask what would be your 1st choice ? i am even willing to use a passive good quality attenuator before the L50 with the pot at max or even bypassed with a little mod ( soldering two pieced of wires)If you want to avoid this completely, you can use devices with ICs for volume control or relay-based volume controls. Both are absolutely precise.
Potentiometers based on switchable individual resistors are only available for retrofitting and don't fit into most devices, including the L50.
i did some test years ago with a cheap resistors attenuator of the series type a 20klog dual channel unit using Holco resistors
i was shocked by the transparency the sounds were cutting the space like blades ... impressive
with the pots the edges are like smoothed out ... i am not good with words
maybe a high quality passive attenuators is the way
