You can adjust it either by pressing the volume button or using the remote control, no problem.
The remote also has two storable user presets, C1 and C2, so you can save two different settings and recall them instantly.
Excellent, thanks. I considered going back to the L30II because of its onboard preamp switch, but it sounds like the L70 can switch back and forth almost as easily. I see that it remembers the last saved volume settings for each too, so that's a plus.
