Topping L30 ii vs. JDS Labs Atom 2
ImDino
I am getting the Hifiman Sundara and I have a Scarlett Focusrite 4i4 4th gen (48 mW over 32 ohms) so I will need a dedicated headphone amp to pair with it.
The only question is, should I go with the L30 ii or Atom 2? I've read the reviews but I'm still not sure.. anybody with experience of the two?
Thanks
Yes! ;)
Really, either is more than fine. The L30 II is somewhat more powerful still and more flexible gain-wise, but the Atom Amp 2 is no slouch by any means and has a second input instead of a pre-out.
Yes! ;)
Got an L30 II on the way :Dthanks
I've not heard the atom amp 2 but I have the l30ii and the sundara,the high gain jst brings the sundara to life,the bass is more powerful,not that the middle gain isn't loud
I can imagine :D I just can't feel the music at my current 48 mW (my Scarlett), and I notice a difference at 180 mW (BTR7), can't wait to try 1W< lol.
Youl be more than satisfied with the l30 with the sundara,
I was definitely satisfied! I paired it up with Sonarworks SoundID Reference. In case you didn't know, you can set a flat profile to then make a personal EQ, I can't understate how much it helped.
