i just got my L30ii a few days ago sounds amazing and very powerful. i hooked it up with my fiio JT7. has more than enough power to drive it..while listening i have the AC brick very close to my desk. and it is emitting a faint odor. gets more noticable when it is warm. is it normal?
I Also noticed a lack of proper Safety Label on the power brick. which doesn't give confidence.
the circle PSE label is considered as category B reserved for low risk electrical appliances. it is a self-declaration scheme label (basically a trust me bro label)
source
a proper PSE listing label, category A (diamond shaped PSE label) is required to be properly tested
by a third party like other safety listings like UL, ETL, etc.
I did found a transformer with the same ratings with proper safety listing labels (available
1.5A version and
1A version)
Problem with it is that the barrel connection of the Jameco Adaptor has a diameter of 2.1mm x 5.5mm while the one in the L30ii is a 2.5mm x 5.5mm so an 2.1mm x 5.5mm to 2.5mm to 5.5mm adapter is needed.
