JDS AtomLooking at picking this up the L30 II and E30 II stack. Are there any other competing stacks in this price range. I’ve been going over ASR this past week and can’t find any. Did I miss one?
Thanks @staticV3! I’ll need the low gain and pre-amp that the l30 II has. Seems like that makes the decision easier. Atom stack does cost a bit more.JDS Atom
Schiit Magni+Modi
You could save some money without sacrificing sound quality by using an SU-1 or C100 DAC, depending on your desired features. Both are a perfect match for the L30 II.Looking at picking this up the L30 II and E30 II stack. Are there any other competing stacks in this price range. I’ve been going over ASR this past week and can’t find any. Did I miss one?
www.audiosciencereview.com
The L30II is a neutral reference Amp which can easily drive your HD600, Ananda Stealth, and AKG headphonesHi. I’m wanting to move on from my Asgard 3 to a more neutral (single 6.3 opt) amp. In this case, would the L30ii be a downgrade, a sidegrade, or an upgrade?
I need something that can still drive my HD600, Ananda Stealth, and my AKG headphones (K701,K702 and K612).
Thanks so much in advance.
Why 'move on' ? What do you want to change ?Hi. I’m wanting to move on from my Asgard 3 to a more neutral (single 6.3 opt) amp. In this case, would the L30ii be a downgrade, a sidegrade, or an upgrade?
Thank you. I think I’m just a sucker for neutrality, and I know Asgard 3 is more “tuby” in its sound, but indeed beautiful. I think I’d like to listen to my headphone’s true signature as close as possible.Why 'move on' ? What do you want to change ?
L30-II is a sidegrade when it comes to available max. output power/voltage.
L30-II is a sidegrade in sound quality and both are equally 'neutral' between 10Hz and 100kHz also the distortion spectrum does not even remotely suggest 'tonal character)
L30-II is an upgrade in technical performance like distortion and noise but only a technical one, not in sound quality (hearing thresholds)
L30-II is much, much cheaper and much smaller.
L30-II has output protection (in case of a fault), Asgard-3 does not.
Asgard 3 can be equipped with an internal DAC card.
How this will unfold 'to your ears' no one can say as you will very likely hear differences but these are not caused by any technical differences.
Thank you once more for your input and advice. I’ll think about it a bit more then.Asgard 3 does not have any 'tube-like' aspects.
Not in output resistance, nor in frequency response, nor in distortion profile and distortion level, it is as 'neutral' as can be.
Power wise it is a sidegrade (basically the same)
The question is what you mean with 'resolution' ?
If it is meant in a technical sense then the L30-II has better resolution simply because it has lower noise and distortion.
Frequency resolution is exactly the same (both >> 100kHz)
When you mean 'perceived' resolution and talk gibberish like 'micro-details'/'plankton' etc then ... who knows how your brain will create something for you.
L30-II will not bring any actual change (equally 'neutral' and equally 'color-less'.
L30-II is smaller, technically a bit better, is lighter in weight and much cheaper.
When you are convinced that Asgard 3 has a (tubey) sound signature and the L30-II will be more neutral you will certainly hear that when changing the amp.
That, however, is not for technical reasons (signal actually differing enough to be audible) but has other causes.
When you are fine with that, want to free some 'space' can offload the Asgard-3 and free a little money in the process that will be a good reason to change.
wow… that’s great to know. Thanks.Another thing worth noting is that the L30 II probably uses less than a third of the power of the Asgard 3 just sitting there burning that class-A idle power, so for those of us with steep electricity rates, the amp will pay for itself over a year or two.
This is total nonsense. It was reviewed here. Please highlight the part of the review which highlighted this "sound". Or are you one of those people who believe you can hear things but cannot measure them?Thank you. I think I’m just a sucker for neutrality, and I know Asgard 3 is more “tuby” in its sound
You’re right. I hadn’t red the Asgard 3 review. Well, I dont know much about amps differences since I’ve only heard very few of them, but almost every review I read mentioned the Asgard 3 not being too neutral and having some warmness in its sound. I guess they are wrong.This is total nonsense. It was reviewed here. Please highlight the part of the review which highlighted this "sound". Or are you one of those people who believe you can hear things but cannot measure them?
For the price of the L30 II and E30 II, you might also want to consider the newly released DX5 II.Looking at picking this up the L30 II and E30 II stack. Are there any other competing stacks in this price range. I’ve been going over ASR this past week and can’t find any. Did I miss one?
After another user provided that same recommendation, I am planning to get one. Thanks for the suggestion, I agree it is a great option.For the price of the L30 II and E30 II, you might also want to consider the newly released DX5 II.
Significantly more power, PEQ, a nice display (with UV meter if needed), remote control, preamp output, etc.
Yes, I love headphones more, but I have most of the Etymotic main family, minus the 3s, and the Moondrop Kato.Yes better for sensitive IEMs because of the lower S/N ratio and lower gain setting.
There weren't any IEMs in your list though.
