staticV3
- Joined
- Aug 29, 2019
- Messages
- 14,245
- Likes
- 24,523
You could if you're curious.Should I also check the output on my headphone amp also?
What you could to is play some music on your DAC->L30 II->ATH-R70x and adjust the volume to your preference.
Then without touching the volume, plug out the headphone, play the 60Hz tone, and measure the voltage at the Amp output (requires something like this to get to the contacts):
Using that voltage, the R70x's sensitivity, and the average and peak dBFS level of the music that you used to set your preferred volume, you can now calculate the average and peak SPL of your audio system.
It's also possible to double-check your Amp's gain this way and make sure it's up to spec.
Simply measure the DAC's output voltage, then the Amp's output voltage with the knob turned all the way up, in whatever gain you'd like to test.
Then do
20*log10(Vout/Vin) and you get the gain in dB.For all of these tests, please make sure that there's no replay gain etc. turned on in your music player. All audio should be played as-is, without any automatic volume adjustment.
